Will these wheels fit? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2007, 03:52 PM   #1 (permalink)
boombringer's Avatar
View boombringer's Photo Gallery
3rd Generation Will these wheels fit?
Will these Wheels fit a Gen3? The detentions say: 17 x 7, PCD 5x100/114.3(I think that means fits 5x100 and 5x114.3) +40 offset. From what I've read on Gen3 Camry wheels these look like they are made for a Gen3. If anyone sees something not working please say something before I order them.
thanks.
boombringer is offline   Reply With Quote
Old 11-20-2007, 04:21 PM   #2 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
Yep, those will work. I don't know what the 10H means, but 17X7 with a 5X114.3 bolt pattern and 40mm offset is good. The bore that they note is larger than the hub on the Camry, but most aftermarket wheels are. Youll need some centering rings to bring the bore down to the correct size for the Camry hub which is like 60.1mm I believe.
eddie926 is offline   Reply With Quote
Old 11-20-2007, 06:46 PM   #3 (permalink)
cool thanks.
Old 11-20-2007, 07:42 PM   #4 (permalink)
'95 Camry V6 XLE
And, you probably knew this, but just in case, when they have 2 bolt patterns, 5X100 and 5X114.3, that means there's 2 sets of holes, so you have 10 holes on the wheel and only 5 will have lugs in them. I only mention that, because some people don't like the look of having the empty holes, and you CAN buy wheels that just have a single bolt pattern. Like I said, you probably already knew that.
Old 11-20-2007, 09:10 PM   #5 (permalink)
Centering rings? I've never heard of them.
Old 11-20-2007, 09:24 PM   #6 (permalink)
'95 Camry V6 XLE
This'll explain it...
http://www.1010tires.com/hubrings.as...FVB1OAodb1sFMw
And this...
http://www.tirerack.com/wheels/tech/....jsp?techid=91
Old 11-20-2007, 09:28 PM   #7 (permalink)
Thumbs up
cool, I saw those when I searched the forum but They were called soothing different. What's the diameter that I need for a gen3?
Old 11-20-2007, 11:44 PM   #8 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
Make sure you put those hub rings on, sometimes some workers who install these stuff on customer cars tend to skimp out these and telling the customers its no big deal dont fall for this!!!
felonyr301 is offline   Reply With Quote
Old 11-21-2007, 10:50 AM   #9 (permalink)
Well I will get them then, What's the inside bore I need?
X-Runner Wheels Bored Out to fit 95.5-04 2wd Tacos Dropitmore Truck/SUV/van parts for sale 11 12-15-2007 12:10 PM
Would these wheels fit my 08? joecap99 5th & 6th Generation (2002-2006 & 2007-2011) 6 11-05-2007 02:00 AM
these wheels do fit jrh3 2nd Generation (2005+) 2 09-25-2007 06:52 AM
**RARE** 17" Inch Mille Miglia Action Wheels *MUST SEE* 95CamBoy Car Parts for Sale 12 05-08-2007 11:33 AM
Will the Lexus GS430 wheels fit on 97 Toyota Avalon dmem1 1st Generation (1995-1999) 7 05-06-2005 09:14 AM
