butterfly valve? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2007, 06:51 AM   #1 (permalink)
View karl_karl's Photo Gallery
3rd Generation butterfly valve?
I bought this throttle body and intake cleaner, part of a 3 step system to clean the engine. It's a spray and asks to remove the air intake boot and locate the butterfly/throttle valve.
Can anyone post a pic or tell me in layman's terms where this is? (5FSE engine)
Much appreciated,
Karl
karl_karl is offline   Reply With Quote
Old 11-21-2007, 09:32 AM   #2 (permalink)
Gameroom cash: $401950
View Stillrunning's Photo Gallery
Remove the air intake tube between air cleaner and throttle body. Butterfly valve will be at the opening of the throttle body. You can open and close it by manually turning the throttle thingy that attaches to the accelerator cable. What I did was fold a paper towel several times and open the valve, then push the paper towel under the valve to absorb the spray and gunk. Then while I held the valve open I sprayed the valve and used a toothbrush to scrub the crap off of it. All that stuff dripped down onto the towel which I was able to remove and throw out.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 185K
Stillrunning is offline   Reply With Quote
Old 11-21-2007, 11:32 AM   #3 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
It's right under the red circle. Just take off your piping. All you will need is a 10mm socket and or Phillips head screwdriver
MIC0417 is offline   Reply With Quote
Old 11-21-2007, 12:54 PM   #4 (permalink)
P.S.
Remove the straw from the spray can valve as you might loose it inside the intake.
Old 11-21-2007, 03:25 PM   #5 (permalink)
Gameroom cash: $275055
Here's a link to a thread on another forum for cleaning of the throttle body. It has some great pictures. It's for a Toyota V6 engine but your engine should be almost identical:
http://www.4x4wire.com/toyota/mainte...throttle_body/
marc780 also posted a good DIY thread on cleaning the throttle body on a 5SFE engine, in this forum. It also has some great pictures. Do a search for threads posted by marc780 and you should find it.
Mike
How to remove the valve cover. 2slo5sfe 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-09-2007 01:26 PM
Is it easy to clean the throttle (the butterfly valve) ourselves? NewRacer Camry & Solara Lounge 9 06-18-2006 08:32 AM
PCV valve is screwed up... I helped it.. 4EVERCooL 1st Generation (1995-1999) 3 11-14-2005 08:55 PM
HELP >>>> Butterfly valve wontonjohnny Camry & Solara Lounge 3 08-26-2002 08:13 PM
