parking brake light on and off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2007, 09:27 AM   #1 (permalink)
View cam01speak's Photo Gallery
2001 camry - whenever i park, i use parking brakes. recently, i noticed that the indicator at the dash comes on and off while driving (when the parking brakes are off). i tried to push the button on the parking stick in (thinking that it might have gotten stuck) and it looked like it worked the first time. but again, i started noticing the light come and go.
any suggestions on where to start troubleshooting this thing?
newb
cam01speak is offline   Reply With Quote
Old 11-21-2007, 09:33 AM   #2 (permalink)
Noob
View gladis's Photo Gallery
Happened to me once, took it to the mecanic
gladis is offline   Reply With Quote
Old 11-21-2007, 10:18 AM   #3 (permalink)
View freestylez's Photo Gallery
pour some brake fluid into the master cylinder and youre set to go
just sounds like your a bit low on brake fluid, that's all
freestylez is offline   Reply With Quote
Old 11-21-2007, 11:08 AM   #4 (permalink)
TN's Nikon Expert?
prnc_chrmng's Avatar
Gameroom cash: $483968
View prnc_chrmng's Photo Gallery
yup, i agree.
ALTHOUGH! have a look at your brake pads and see if they need changing (they probly do)
Originally Posted by 98tercel_girlie
This thread needs more porn, less blah blah
prnc_chrmng is offline   Reply With Quote
Old 11-21-2007, 11:12 AM   #5 (permalink)
PDR Tech
feliks's Avatar
View feliks's Photo Gallery
Low brake fluid light and e-brake light are the same light for some reason.... Was like that on my Celica too!
feliks is offline   Reply With Quote
Old 11-21-2007, 12:24 PM   #6 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
yep - happened to me a few months ago ... filled the brake fluid up and it went away
the fluid might not look low, but when your car turns it may trip the sensors - so make sure you get it completely full (theres a max line)
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 11-21-2007, 03:21 PM   #7 (permalink)
Gameroom cash: $275055
After refilling the master cylinder back up to the max line, as the others have suggested, take the car somewhere to have your front brake pad thickness and rear brake shoe thickness (or pads if you have discs in the rear) checked. You can also check this yourself if you know what you are doing. When the fluid goes down far enough to trip the sensor, it usually indicates that the pads (and/or rear shoes) have sustained a lot of wear. It may be time to replace them.
Mike
