Removing the y-pipe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2007, 12:46 AM   #1 (permalink)
View J_Phu's Photo Gallery
3rd Generation Removing the y-pipe
Would removing the y-pipe and running seperate pipe for each exhuast manifold to dual exhuast do any good or is it just a wast of time and money
J_Phu is offline   Reply With Quote
Old 11-22-2007, 12:56 AM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $511687
iTrader Score: 27 reviews
View bigbird's Photo Gallery
honestly, no one here has ever tried it as far as i know. the biggenst thing would be the cost for the extra cat and all the tuubing. in my experiance dual exhaust does help with high hp cars but im not sure if it would make any mopre differance then a bigger and better flowing Y-pipe and exhaust.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 11-22-2007, 01:03 AM   #3 (permalink)
well for the piping and cat. I'm thinking bout getting a set from the junkyard. So I probably won't feel any power than? since the monly mod I did was SRI and lean fuel/ 17 degree timing advance
Old 11-22-2007, 01:17 AM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $359260
iTrader Score: 13 reviews
it would make a difference....but the problem with our cars is mostly in not having the room to run a true dual exhaust setup as well as not being able to keep the header lengths equal then
HaHa
Old 11-22-2007, 01:18 AM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
if ur running duals ur pretty much gonn have to rework the entire exhaust, junkyard stuff aint gonna cut it. and dont try to half ass somthing that my add some power(may not). do it right if ur gonna do it at all.
if he was runnign duals though they would only have to be the same distance to tthe cat right? he could do waht GM did with the GTO and run them side by side through the channel and there should be enough room if u kee them pretty tight.
R.I.P.
Car Domain:
Old 11-22-2007, 01:48 AM   #6 (permalink)
well if junkyard stuff aint gonna cut den I guess I can get some cheap pipes and cat from ebay. And yea my plan was to run the pipes side by side and keaping the distance from the manifold to cat the same distance. HOw would you think it might sound tho? I assume it won't sound low and deap as of my current setup
Old 11-22-2007, 02:01 AM   #7 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
what king said
it will help, but youre gonna have a hell of a time trying to get equal lengths and space under the car ....\
the exhaust tones shouldnt change much ... the volume should increase tho
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 11-22-2007, 02:11 AM   #8 (permalink)
well getting the length equal or atleast close isn't really hard, I think. But as everyone else said about the spacing I must agree. I can always go down to 2inch piping and get a little more low end torque, also makes it a little easier to get things to fit
Old 11-22-2007, 02:29 AM   #9 (permalink)
Venom_5's Avatar
i wouldnt go down to 2" piping .... youll lose more than you'll gain from adding the restriction
its not that you cant fit 2.5" piping anywhere, its that the underside of our cars are just so cluttered .... there is only enough space for one exhaust path really .... im sure its been done before, you just have to carefully map out where youre going to run piping - especially since the pipes for the rear 3 cylinders are going to need more room to create some sort of loop to make both pathways equal length
Old 11-22-2007, 02:42 AM   #10 (permalink)
Wow this is really starting to look like a headache to do. I haven't really thought about doing a loop for the rear cylinder. Can't I just go without the loop and do like a 90 degree bend and go striaght from there instead?
Old 11-22-2007, 11:04 AM   #11 (permalink)
I HAS BOOST!!!
bigbird's Avatar
2.25" would be best anything more on this NA engine with duals is gonna be way to big. but even if u did go 2" ud still get gains since there is actually less volume moving through the pipes. u cut the restrictionin half alerady. but like ya said, actually working the piping would be the toughest part and it would cost alot to do it right.
the sound maybe somthing like this. now this guy as 2.5" and flowmasters.
http://youtube.com/watch?v=23_qEqPcWvU
R.I.P.
Car Domain:
Old 11-22-2007, 11:28 AM   #12 (permalink)
No Fat Bitches
iTrader Score: 10 reviews
View PtBaller's Photo Gallery
Here is a setup that was done by a solara owner
^ Volk Racing CE28s 19x8.5/8 for sale
PtBaller is offline   Reply With Quote
Old 11-22-2007, 11:36 AM   #13 (permalink)
Venom_5's Avatar
^ appears to be unequal length, but fairly large sized piping
and an easy solution
Old 11-22-2007, 01:18 PM   #14 (permalink)
1999 camry 4 banger
View matt9112's Photo Gallery
solara underbody same as the reg camrys?
1999 camry 2.2
custom painted interior
custom cold air intake
matt9112 is offline   Reply With Quote
Old 11-22-2007, 01:25 PM   #15 (permalink)
Venom_5's Avatar
^ if not the same, damn near close....
i think you could do the same thing on my gen 3 ^
except you would have to get cats like this (Magnaflow #54305 ... 2.25"):
Banks Monster Exhaust SR5-2006 2nd Generation (2005+) 30 08-28-2007 07:53 PM
turbo abew330 Supra Forum 0 02-07-2007 06:51 PM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 02:41 PM
Double check... _VVTi_ Camry & Solara Lounge 43 04-22-2004 02:25 AM
