3VZ-FE ACIS valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2007, 11:51 AM   #1 (permalink)
European Camry Fan
View deepsun's Photo Gallery
3VZ-FE ACIS valve
Hi guys,
one question: As far as I understood, the ACIS valve on the 3VZ-FE engine should be CLOSED below around 4000 rpm. Closed means the vacuum solenoid should be activated.
Is that also true in idle rpm and when the car is not driving?
(If I let the engine run, car stationary, and let the engine rev up (standing in front of the car and looking at the ACIS) it does not do anything.
Is that ok or? Or is it broken?
Thanks a lot for help!
Cheers,
deepsun
1993 Camry Wagon 3VZ-FE
deepsun is offline   Reply With Quote
Old 11-22-2007, 12:36 PM   #2 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
The ACIS is always open and closes (from my experience) when over 4000rpm and WOT. The ACIS will likely do nothing when revving the car.
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Old 11-22-2007, 08:52 PM   #3 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
when parked you can only see it working if you flip the throttle wide open you'll see it move a bit. (while running). its made (from what i remember) to actuate only when above 3K rpm's, and at WOT.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 11-23-2007, 04:13 AM   #4 (permalink)
European Camry Fan
Thanks a lot for the feedback!!
turbo abew330 Supra Forum 0 02-07-2007 05:51 PM
Valve Adjustment 1zzfe medicstudent01 Archived Corolla threads 3 12-08-2006 10:30 AM
A small mistake... need new valve covers east_stingray 89-95 Toyota Pickup/Hilux 6 12-02-2006 06:19 PM
92 3VZ FE Failed Emissions !!!!? scprandy 3rd & 4th Generation (1992–1996 & 1997–2001) 4 01-31-2006 10:51 AM
3VZ FE Head Removal scprandy Camry & Solara Lounge 5 01-16-2006 02:32 PM
