Subwoofer Self-Install Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-23-2007, 11:07 AM   #1 (permalink)
It's pronounced "Nesquik"
View N35QU!K's Photo Gallery
3rd Generation Subwoofer Self-Install Help
Hello, everyone
I just got a hold of a set of 10" subwoofers with amp included today. So my big question is this:
Is there a DIY somewhere that shows you how to install subs?
Yes, I tried the search, and nothing along the lines of instructions came up.
Click image for vehicle info (UPDATED 12.01.09)
N35QU!K is offline   Reply With Quote
Old 11-23-2007, 11:49 AM   #2 (permalink)
1999 camry 4 banger
View matt9112's Photo Gallery
so the sub has a built in amp or is it a seprate unit that just came with it?
1999 camry 2.2
custom painted interior
custom cold air intake
matt9112 is offline   Reply With Quote
Old 11-23-2007, 11:53 AM   #3 (permalink)
1999 camry 4 banger
its basicly this you need to run wire from the speaker/speakers to the amp and from the amp to the headunit there is an amp input thingy on the rear of your headunit the wire from amp goes here than u need to power it i belive you run a wire directly to the battery i havent done any of this friends have but hope it helps
1999 camry 2.2
Old 11-23-2007, 12:13 PM   #4 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Did you get an amp installation kit?
How many watts is your amp rated at?
How many watts are the subs rated at?
Depending on that info you're either gonna be using 8 or 4 gauge wiring.
Basically you run a power wire from your battery to your amp, you MUST have a fuse or circuit breaker in between.
Then you use speaker wire to connect the subs to the amp
Then you connect a ground from your amp to a ground spot on your car. The ground wire should be the same gauge as your power wire and less then 1 foot in length.
The spot you ground it on should be free of paint and any debris.
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Curry is offline   Reply With Quote
Old 11-23-2007, 01:01 PM   #5 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
You want the fuse as close to the battery as possible because the section of wire between the battery and fuse is not protected.
2007 Camry 2.4L 5M
Old 11-23-2007, 03:56 PM   #6 (permalink)
If by installation kit, you mean all the wires and cables I need, then yes.
It comes with an amp, and its rated at 800W.
And another question, do I need a new headunit? My 92 LE has the basic casette player/radio.
Old 11-23-2007, 04:14 PM   #7 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
its better if you have an aftermarket so you can just plug the racs and dont need a line out put converter.. but if you want i can make DYI for ya... might take me a day or teo due to be busy..
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 11-23-2007, 04:29 PM   #8 (permalink)
Curry's Avatar
An after market head unit should have been the first piece of equipment you got. Followed by interior speakers and then subs.
One very important reason for the new HU are the pre-amp outputs.
Many people are under the impression that sub woofers will make your music sound better. Not that they don't but without the proper upgrades, all you've got is unbalanced sound. They then complain later that they can't hear the words to the music anymore. HM I wonder why!
94' Camry V6 - Sold
99' GS300 - Sold
Old 11-23-2007, 04:32 PM   #9 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
get a deck first! you have an older car so its much easier to get a deck installed rather than the new cars with all the fancy dashs where its like impossible to put in a after market deck. (well they make it alot harder)
CamrySExxx is offline   Reply With Quote
Old 11-23-2007, 05:10 PM   #10 (permalink)
PDR Tech
feliks's Avatar
View feliks's Photo Gallery
Get a deck.
Go to www.crutchfield.com
They show EVERYTHING you need to know about installations.
feliks is offline   Reply With Quote
Old 11-23-2007, 05:13 PM   #11 (permalink)
PDR Tech
feliks's Avatar
quick link
http://www.crutchfield.com/ISEO-rgbt...ion_guide.html
Old 11-23-2007, 08:36 PM   #12 (permalink)
Alright, I just bought a deck. Now I just need to put it in. How do i take out the old one?
Old 11-23-2007, 10:08 PM   #13 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
pop out the u-trim below the radio. it's held in by two clips. once that is off, disconnect the cig lighter.
there's two bolt on each side holding in the radio unit. screw those off, slide the old unit out and disconnect cables. remove brackets from old unit since you might wanna use them
that's about it, really.
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 11-24-2007, 01:23 AM   #14 (permalink)
Black95Cam's Avatar
thats the opposite from which i did.. its not bad you just have to wait longer before putting your subs and amp to work. when your connecting the wiring harness please try to soldier and shrink/heat warp. it will pay off. if you can get those then when using electrical tape, tape it well dont half-ass like my buddy did and have his whole wiring system get fried. and zip tie it up just to clean it up and easy to pull out the deck if need. ($1200 just to reaplce the wiring harness)
Infinity BassLink II 10" Subwoofer 250W RMS Install Pics Yazovets 5th & 6th Generation (2002-2006 & 2007-2011) 20 09-24-2007 04:49 AM
Mechanical Oil Pressure Gauge Install Stillrunning 3rd & 4th Generation (1992–1996 & 1997–2001) 0 09-05-2007 05:12 PM
5sfe Engine Install xylium 3rd & 4th Generation (1992–1996 & 1997–2001) 9 04-08-2005 02:07 AM
Rod Millen 92-94 Add-on Install Zer05 3rd & 4th Generation (1992–1996 & 1997–2001) 3 10-28-2003 10:25 AM
Subwoofer Install? CamrySpeaksJL Audio, Video, and Security - Tech 17 02-07-2003 08:33 AM
