Originally Posted by wahed3001
Did you notice any difference in shifting while driving? How did you drain the extra fluid? I wanted to loosen the drain plug and then re-tighten it but you're supposed to change the plug gasket every time you loosen it.
I didn't drive the car overfilled, so I don't know how it would have shifted. P-D shock was enough to make me stop and fix it.
I've reused the gasket on the old car a few times now. So long as it's flat all the way around with no gouges it shouldn't leak. I loosened the plug until the last thread or so then very carefully let a little fluid out and promptly tightened it up.
I also tried to siphon it out using some tubing I had laying around, but I couldn't get it past one of the bends in the dipstick tube.
