Oil leak from oil filter area...with pic - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2007, 01:51 PM   #1 (permalink)
I don't sugarcoat!!
View camrycoupe95's Photo Gallery
95 Camry, 2.2L, Automatic, 145,000 miles...
Oil is slowly dripping from the filter area. Thought it could be the valve cover gasket but there is no oil from up there, it's definately coming from the filter. What sucks is the oil drips down on the hot exhaust manifold creating smelly white smoke.
There are 2 hoses that lead to the right side of the base of where the filter screws on to, is that for an oil cooler? Those hoses look fine, could there something else in there that is causing the leak? Thanks...
1985 AW11
Past Toyota products --1989 Corolla SR5, 1995 Camry LE Coupe, 2002 MR2 Spyder, 2006 Scion xA
camrycoupe95 is offline   Reply With Quote
Old 11-24-2007, 01:54 PM   #2 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
I had this problem before and it turned out to be the oil filter.
Did this just start happening out of nowhere or did you just put a new filter on?
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Curry is offline   Reply With Quote
Old 11-24-2007, 02:50 PM   #3 (permalink)
I don't sugarcoat!!
It's been leaking for a couple oil and filter changes. The filter is screwed down tight.
1985 AW11
Old 11-24-2007, 02:50 PM   #4 (permalink)
the honda killa
rholzboog's Avatar
View rholzboog's Photo Gallery
did you clean the filter hub and rub oil around the filter gasket
catch me if you can
rholzboog is offline   Reply With Quote
Old 11-24-2007, 04:18 PM   #5 (permalink)
View karl_karl's Photo Gallery
3rd Generation
I had the same problem with my 94 5FSE. I cleaned up the filter area and bought a better filter and screwed it down tighter. No more leaks.
Does the leak leave tiny drip marks underneath where you park?
karl_karl is offline   Reply With Quote
Old 11-24-2007, 04:32 PM   #6 (permalink)
I don't sugarcoat!!
Yeah, there are a few drops on the driveway after I drive it. I'll have to check for crap left on the filter hub. The last couple oil changes I had done at a quick lube place since I don't have somewhere to do it myself anymore. It's possible that the guy didn't rub oil on the gasket.
Hopefully it's just something as simple as improper filter installation. It just seemed too simple to be that, thought it had to be something bigger. Thanks for the help.
1985 AW11
Old 11-24-2007, 06:38 PM   #7 (permalink)
View OEMonkey's Photo Gallery
Check exactly where it's leaking. Might just be the filter. Might just be residue fr last oil change. Only other oil leak source directly below the filter would be the oil cooler. Either the cooler needs a new gasket and oring or it has come loose.
Remove the oil filter and see if the big nut is tight on the relief valve(this is where you screw in the oil filter.) If it's loose, it'll leak oil around the oil cooler. Tighten it if it's loose. You'll need a big socket, forget what size.
When the oil filter is overtightened, the big nut on the relief valve will loosen when you remove the oil filter during oil changes. Those quick lube places tend to overtighten oil filters and strip drain plugs.
OEMonkey is offline   Reply With Quote
Old 11-24-2007, 09:36 PM   #8 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
The oil cooler has an o-ring that wears out after a while, it's a pretty straight forward job. Pick one of from the dealer for a few bucks and change it.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 11-25-2007, 02:29 AM   #9 (permalink)
97 Camry '8ball EDITION'
rebel8ball's Avatar
View rebel8ball's Photo Gallery
had an old transam that had that happen to it, turns out i had put the new filter on over the oring from the old filter...
rebel8ball is offline   Reply With Quote
Old 11-25-2007, 09:18 AM   #10 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
Do you use crush washers when you put your filters on? If not, you might try using those. You'll get a better seal.
eddie926 is offline   Reply With Quote
Old 11-25-2007, 05:24 PM   #11 (permalink)
View unkit's Photo Gallery
I had the same problem a while back in my 94 5s -fe.... it was the o ring.....
unkit is offline   Reply With Quote
Old 11-26-2007, 12:06 AM   #12 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
You asked about the two hoses going to the base of the oil filter. These supply engine coolant to the oil cooler (the hub at the base of the oil filter).
Since this began happening after you began taking it to a lube center I would encourage you to find a place where you can do it yourself once more and see if they have damaged something or just didn't do the job right. However, I suspect qslim's evaluation is more likely since the base of your filter doesn't appear very oily, just the top of the engine.
Kep
97 2.2l oil leak help bronzemaxell 3rd & 4th Generation (1992–1996 & 1997–2001) 3 10-15-2007 09:10 AM
oil cooler kj_mechanic 2nd Generation (2005+) 0 11-21-2006 09:34 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 04:39 AM
