Battery Being Drained? Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2007, 04:31 PM   #1 (permalink)
importcars's Avatar
View importcars's Photo Gallery
Unhappy Battery Being Drained? Help
95 Camry LE..
Alright, first thing happened, when i tried to start my car there was a extremely rapid clicking.. I have experinced this before when i had a bad battery.. I got the battery replaced
4months later, I try to start the car.. Same thing happend.. I dont believe its a bad battery?
I get it brought to autozone, they test the battery, its good. He said something is draining the battery, b/c he watched it being drained while he had it hooked up.
So i was sure it was the starter or alternator
Today: I just went to autozone, after removing the Starter and Alternator, taking both to be tested.. Both PASSED
Now im lost? I have no idea what it could be? Any help would be greatly appreciated, any questions that i missed, just ask, and i will try and shed some light.
EDIT: Currently to keep my car working, i unplug the ground wire to for the battery so whatever is running the battery down does not harm it.. and i just hook up it up before i go somewhere and its fine..
importcars is offline   Reply With Quote
Old 11-24-2007, 06:06 PM   #2 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Originally Posted by importcars View Post
95 Camry LE..
Sounds like you have a parasitic draw somewhere. If you have a meter and you're comfortable with doing a little poking around, it's not too tough to begin to isolate where the problem is. All cars now will have a little draw when the car is off because of various timers and clocks in the computer, but not enough to kill the battery during normal usage. I don't have the exact figure infront of me, but ball park acceptable draw is 20 - 30 miliamps (.02 - .03).
-Get a meter, set it to the proper scale, disconnect the - battery terminal and put the meter in series. Shut the car door, take the key out, and let the computer go to sleep (30 secs or so).
-Look at the amperage the meter is showing. This is the juice that the car is drawing while it's sleeping. The theory here is to start pulling fuses and unplugging things to isolate the circuit that is pulling the current while the car is off. When you find it, the reading should drop down to an acceptable level.
-Start with anything aftermarket, these are usually the prime suspects (radios, amps, radar detectors, cell phone chargers, etc.). Check the alternator and starter too, because the test at autozone wouldn't necessarily reveal a current draw problem. Pull the starter relay and disconnect the battery wire from the alternator.
Anyway, that's a start. Hope it gets you in the right direction.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 11-24-2007, 06:22 PM   #3 (permalink)
TN's Nikon Expert?
prnc_chrmng's Avatar
Gameroom cash: $490868
View prnc_chrmng's Photo Gallery
yeah, id say start with any aftermarket elecrtonic you have. start with the last thing you added.
Originally Posted by 98tercel_girlie
This thread needs more porn, less blah blah
prnc_chrmng is offline   Reply With Quote
Old 11-25-2007, 02:20 PM   #4 (permalink)
Gameroom cash: $303055
Many times I have seen this type of accessive "dark current draw", as it's called, traced to a defective aftermarket alarm system. If you have an aftermarket alarm on the car, it would be the first thing I would check, using Qslim's procedure. They usually have an inline fuse on them.
Mike
Old 11-26-2007, 12:25 AM   #5 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Kind of like qslim proposed, put an in-line meter (or light) between the battery and the battery cable (I don't think it matters if it is the positive or negative one). You should get a light or a meter reading. Start pulling the fuses one by one (keep track of which one came from where) until the current stops (light dwindles or meter reading drops to normal). Once you determine which circuit (fuse) is responsible you can begin checking the accessories on that circuit..
Kep
Old 11-26-2007, 06:06 AM   #6 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
This should help as well as what everyone else posted:
http://www.autoshop101.com/trainmodu...rvice/118.html
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Battery dies after 3 -4 days capinoy 89-95 Toyota Pickup/Hilux 13 06-05-2007 10:37 PM
Battery Problems haux Camry & Solara Lounge 3 09-21-2006 12:48 AM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 09:21 PM
Drained Battery ricochet57 Hardcore Tech and Competition 1 01-29-2005 11:41 AM
Battery ?'s 1995 camry V6 LE kenny1773 3rd & 4th Generation (1992–1996 & 1997–2001) 14 11-29-2004 03:29 PM
