maintenance problem on 1997 camry LE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2007, 09:23 PM   #1 (permalink)
View tommytang's Photo Gallery
Question maintenance problem on 1997 camry LE
I bought a 1997 Camry LE with 140500 mileage this Sep. from a dealer. The dealer didn't have ower's manual for me and didn't know when was the last time the timing belt was replaced. It was my first time to buy a car and I knew little about car. After reading post on the forum, I get a little familiar with car. I have questions on how to maitain the car:
1. Should I replace the timing belt for this moment (the mileage is 141000)? If not, when?
2. What kind of engine oil, brake fluid, transmission fluid and coolant should be used for my car?
3. The warning LED of hand brake was sometimes on even if I had released the hand brake. What's the possible cause and what should I do to fix it?
Thanks a lot for your kind answer.
tommytang is offline   Reply With Quote
Old 11-25-2007, 02:32 AM   #2 (permalink)
97 Camry '8ball EDITION'
rebel8ball's Avatar
View rebel8ball's Photo Gallery
the brake warning you are getting is low fluid in the resevior, usually from your brake pads getting worn down, mine was doing the same thing, so i added aa little fluid untill i am ready to put on new brakes (hoping to change brakes and rotors at once)
rebel8ball is offline   Reply With Quote
Old 11-25-2007, 04:01 AM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
The timing belt is supposed to be changed every 90000 miles. Are there any service records for the car? If it was not replaced at 90000 miles, it should be replaced now, otherwise, the car may leave you stranded somewhere.
Engine oil is 5W-30, DOT 3 or 4 brake fluid, transmission uses Dexron III, and coolant use either the green stuff, Toyota red, or Zerex G-05.
2007 Camry 2.4L 5M
Old 11-25-2007, 09:21 AM   #4 (permalink)
Thumbs up
Thank all you guys for your useful response. I appreciate them very much.
1990 Camry LE Heater Problem John Martens 1st & 2nd Generation (1983–1986 & 1987-1991) 16 12-28-2010 07:37 PM
1997 Camry LE Just need someone to give me step in the right direction Tru NYY Fan Audio, Video, and Security - Tech 6 11-04-2007 01:04 AM
2001 Camry LE power window problem loonmobile Introduce Yourself Here 1 06-27-2006 09:47 PM
1997 Camry tranny problem.. I think! YotaMan21 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-25-2005 10:09 PM
Damage to 1997 Camry LE chrono807 General Discussion 8 07-28-2004 04:52 PM
