Power Steering Leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2007, 11:01 AM   #1 (permalink)
View Jertk's Photo Gallery
3rd Generation Power Steering Leak
Hello all,
I have looked through the forums so I hope I'm not posting the same question. I couldn't find any specific symptoms related in other threads. I have a 93 Camry V6, I have been having problems with power steering fluid leaking. It doesn't leak when the car is parked or sitting for a long period of time however when driven, the power steering fluid drops drastically. I have had it in 4 different mechanics shops, all attempted a pump replacement, luckily under pump warranty, and no success. I have been told that the system runs in conjunction with the coolant system. If this is incorrect let me know and any suggestions are greatly appreciated. Thank you very much.
Jertk is offline   Reply With Quote
Old 11-25-2007, 03:51 PM   #2 (permalink)
Unco's Avatar
View Unco's Photo Gallery
Originally Posted by Jertk View Post
Hello all,
it is incorrect
it could be a high pressure hose. i find it difficult to accept that 4 different mechanics have been unable to find the problem, though.
all you need to do is dregrease the affected area so that it is completely dry and clean. then start the engine and turn the wheel from lock to lock. that's usually enough to find the source of the leak.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 11-25-2007, 07:00 PM   #3 (permalink)
View toyomoho's Photo Gallery
Some older cars had hydraulic operated radiator cooling fans, see if you have one. If so, the PS pump also runs the motor for this fan.
If the leak is only when the engine is on it is coming from a hose or device that is under fluid pressure. Place some cardboard under the car with engine running and see where the drip lands, then find the location on the car. Could be the pump, hoses, PS actuator, rack seals, etc.
'93 Camry Power Steering Problem joeantispam 3rd & 4th Generation (1992–1996 & 1997–2001) 20 10-23-2011 07:34 PM
power steering troubles mazdaverx7 3rd & 4th Generation (1992–1996 & 1997–2001) 15 05-08-2007 09:13 PM
Power Steering Leak Kay338 Celica Forum 2 08-24-2006 03:25 PM
Power steering noise after flushing/changing the steering fluid Camry 2001 Mark22 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-26-2005 12:34 PM
Power Steering Leak on 92 5sfe kartracer03 3rd & 4th Generation (1992–1996 & 1997–2001) 3 02-11-2005 08:31 PM
