Oil leaks on '97 Camry 5SFE (pics) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2007, 11:08 AM   #1 (permalink)
View bcsbadboys's Photo Gallery
4th Generation Oil leaks on '97 Camry 5SFE (pics)
This picture is from under the engine and the leak is dripping under the ignition coil area off the black plastic.
This picture is from under the passenger side of the engine and the leak is coming from above the power steering pulley.
I'm losing engine oil, not power steering fluid. Any gaskets/seals to look at?
1997 Camry LE 2.2L, 5SFE
160,000
bcsbadboys is offline   Reply With Quote
Old 11-25-2007, 08:07 PM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
since its coming from above the power steering, my educated guess would be the cam seal. i had a similar leak when mine went bad. to know for sure, pull off the timing timing belt cover and get a better look.
Old 11-25-2007, 11:13 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
There is also an oil pump seal behind the timing cover. Might be that.
Check inside the distributor cap. If there is oil inside the cap the inner gasket is leaking. There is an aftermarket replacement if you want to try and rebuild it. Toyota suggests replacing the distributor body. If there isn't oil inside the cap it may be the exterior seal (between the distributor body and the engine). This is sold by Toyota and is easy to replace.
You might want to clean off the area with a paper towel and see if you can't get a better idea where the oil is originating from.
Kep
Old 11-27-2007, 03:28 AM   #4 (permalink)
View djb2's Photo Gallery
The o-ring around the distributor drive is about $5 at the dealer. Expensive for an o-ring, but cheaper and easier to try than most of the other fixes for leak points.
djb2 is offline   Reply With Quote
Old 11-27-2007, 07:16 AM   #5 (permalink)
ghettosled's Avatar
Kep
a distributor leak would be on the drivers side of the motor and not the passenger, right? oh wait, do the gen4 models even have a distributor? i thought the '96 camry were the last of them.
Old 11-27-2007, 01:28 PM   #6 (permalink)
Kep
Kep's Avatar
No distributor? Sacrilege!!!!
Ghettosled, you're undoubtedly right. Disregard the distributor comments. My bad. Boy, I really liked distributors.
Kep
Old 11-27-2007, 03:36 PM   #7 (permalink)
I will take a look at the cam seal. What about the leak on the drivers side by the ignition coils?
160,000
How to Turbo the Camry - 5s-fTe tips and information Hamsterman Camry & Solara Lounge 118 09-23-2010 10:43 AM
How to change 95 camry transfer case oil? minime3 3rd & 4th Generation (1992–1996 & 1997–2001) 3 12-02-2005 04:15 PM
Oil leaks on Gen 4 eyeball96 3rd & 4th Generation (1992–1996 & 1997–2001) 12 10-20-2005 03:56 AM
1992 Camry Oil Leak 4cyl kartracer03 3rd & 4th Generation (1992–1996 & 1997–2001) 18 02-04-2005 11:19 AM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 04:39 AM
