problem on adding brake fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2007, 09:02 AM   #1 (permalink)
View tommytang's Photo Gallery
Question problem on adding brake fluid
I bought a 1997 Camry LE this Sep. and I don't know what kind of brake fluid the former owner was using. Now I need to add some brake fluid. Can I buy the brake fluid from Autozone or Wal-Mart and then add the newly bought brake fluid to the old one directly? Or do I need to clear the old brake fluid firstly?
tommytang is offline   Reply With Quote
Old 11-26-2007, 01:35 PM   #2 (permalink)
wtftoy's Avatar
View wtftoy's Photo Gallery
What color is the fluid now? New fluid should be clear so if its really dark or brown-ish.....just bleed it out and put in new dot 3 brake fluid.
And if you get brake fluid on your paint, make sure you WIPE IT off IMMEDIATELY.
1998CamryLEV6
Tokicos,Eibachs,TrdRSB,Intake,Jim'sTorqueRod.
wtftoy is offline   Reply With Quote
Old 11-26-2007, 01:35 PM   #3 (permalink)
wtftoy's Avatar
double post! sry
1998CamryLEV6
Old 11-26-2007, 01:53 PM   #4 (permalink)
Sorry for the repeated post. When I posted the first one, there was problem with the network so I thought I didn't succeed. I can't tell the color because I see through the brake fluid reservoir.
Old 11-26-2007, 02:03 PM   #5 (permalink)
wtftoy's Avatar
You can open up the cap of the reservoir and take a look.
1998CamryLEV6
Old 11-27-2007, 03:13 AM   #6 (permalink)
View djb2's Photo Gallery
Use DOT-4 brake fluid such as Valvoline or Castrol LMA. It has much better performance and is compatible with existing DOT-3 or DOT-4 fluids. DOT-4 does cost a bit more more than DOT-3, but brake fluid is inexpensive, you need only a bottle to freshen the system, and it's not consumed.
If you buy a 12oz bottle, bleed about 3oz from each rear brake cylinder and about 2oz from the fronts, reserving the last bit to top off. Refreshing the fluid at every brake pad change, or at least every few years, will keep the system rust-free.
djb2 is offline   Reply With Quote
Brake fluid change (flush) - write-up kocho 3rd & 4th Generation (1992–1996 & 1997–2001) 37 08-28-2010 01:19 AM
power steering fluid colour!? wtf 95 COROLLA Archived Corolla threads 14 06-02-2009 10:18 AM
tranny dipstick? karosR6 2nd Generation (2005+) 18 04-11-2009 03:01 AM
99 corolla brake fluid Spillner Archived Corolla threads 8 04-30-2007 01:51 PM
96 Previa Brake Light Problem dreamakr20 Previa Forum 8 08-09-2003 01:29 AM
