Brake Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2007, 10:37 AM   #1 (permalink)
The Greatest
View CamNub's Photo Gallery
Brake Light
I haven't had much time to research this, but the Camry was on the driveway all night w/ the Ebrake on.
This morning, I put it down, but the "Brake" light was still illuminated on my dash. Anyone have a clue as to why? The Ebrake was completely down.
I suspect that somewhere there is a screwed up connection (something is making the connection to turn on the light), but maybe someone else can shed a little light onto this problem...
CamNub is offline   Reply With Quote
Old 11-27-2007, 01:17 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Long shot but you're up in Minn. Check your brake fluid reservoir. Since it got cold up there the fluid may have contracted enough to trip the light. Overnight it gets the coldest.
Kep
Old 11-27-2007, 06:21 PM   #3 (permalink)
Gameroom cash: $303055
90% of the time when this light stays on, the master cylinder is low on brake fluid. Top it off to the "MAX" line and the light should go out. Then, as soon as possible, have your front brake pads (and/or) rear drums/pads checked for minimal thickness. When the master goes down this far, it usually indicates some wear on the pads/shoes.
Mike
3rd brake light fuse popping gameguru1360 Archived Corolla threads 4 03-15-2007 03:21 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
1991 PU Check brake light jaydub 89-95 Toyota Pickup/Hilux 2 11-11-2005 10:32 PM
3rd Brake Light Blowing Bulbs? rkersh409 Camry & Solara Lounge 0 03-08-2005 07:58 AM
L.E.D. Tail/brake light & 3rd brake light conversion project eviltwin67 Camry & Solara Lounge 2 07-02-2003 10:24 AM
