q about changing tranny fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2007, 10:56 AM   #1 (permalink)
View charley240sx's Photo Gallery
hello TN. i had a quick question pertaining to changing the tranny fluid. since i wont be driving my vehicle in a couple of days, i was wondering if i just drained and dropped the tranny pan, and left it to drain for a couple of days, would that get most of the tranny fluid out? sorry for the noob question. i know a lot of it is behind torque converter. but will that be able to come out? i would like to get most of it out, and figured that it sitting on jackstands would drain majority of tranny fluid of a period of 3days.
Thank You
Charley
charley240sx is offline   Reply With Quote
Old 11-27-2007, 01:11 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
No joy, if you do a quick drain you will probably get about 2.25 quarts out. If you let it sit for days maybe you'll pick up another pint (if that). The torque converter has a reservoir that the fluid sits in like a bucket.
Kep
Old 11-27-2007, 01:43 PM   #3 (permalink)
hmm. that sucks. was planning on disconnecting the tranny cooler lines connected to the radiator, but have not had experience with that method of tranny draining. i want to do a complete drain. but also would like to take the pan off as it currently has 193,xxx miles and has yet had the tranny pan pulled to be cleaned.
btw, this is a 1997 lexus Es300 1mzfe autotastic.
Charley
Old 11-27-2007, 01:50 PM   #4 (permalink)
Really a good idea to remove the pan and clean out the sludge ..... mine had a considerable amount at 44k.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 11-27-2007, 02:35 PM   #5 (permalink)
yeah, i cant even imagine how much mine will have at 193k.
Charley
Old 11-27-2007, 09:14 PM   #6 (permalink)
Kep
Kep's Avatar
Charley240sx, if you have 193000 miles and this is your first transmission oil change I would advise you to do a search of this forum and the gen 1-2 forum. There is a lot of disagreement whether or not to change the oil at all if it has been allowed to go for over 100,000 miles since the last change.
I took a middle of the road approach and drained my transmission pan (about 2 quarts each time) every couple of weeks ten times with high milage transmission fluid. It seemed to work without stressing the transmission.
A couple of guys have written how to do a DIY flush. Two of these are 1) kocho at: http://www.toyotanation.com/forum/t9830.html and 2) heat at: Should I flush the tranny?
They both seem pretty straight forward if you decide to do this.
Kep
Old 11-27-2007, 11:07 PM   #7 (permalink)
Gameroom cash: $152705
View redgtxdi's Photo Gallery
I thought it was whether or not to *flush* if it was over 100,000 miles??
I thought drain was ok at any given time.
I'm a big fan of drain/fill over a few consecutive weeks.
Heck, if we changed our trans oil every time we changed engine oil (3 mos. or so) we'd probably all have zero oil related trans probs.
redgtxdi is offline   Reply With Quote
Old 11-27-2007, 11:58 PM   #8 (permalink)
well, i wasnt necessarily going to do a flush, like as in a pump commercial unit flusher. i was planning on dropping the pan first and clean. then flush with cooler lines. i dont know though. i have yet to do it. but i wouldnt consider myself a beginner with cars. but a beginner to tranny junk.
btw, my tranny was flushed at 140k approximately 1.5 years ago. but i do not plan to go with a flush flush. but rather a DIY homestyle flush. lol. i make up all kinds of mumble jumble words.
KEP- thanks, im going to read those articles now.
TIA TN.
Charley
changing auto tranny fluid bad? dropd4door 89-95 Toyota Pickup/Hilux 8 04-09-2007 06:16 PM
tranny fluid changing..143k azpaquin 89-95 Toyota Pickup/Hilux 2 09-10-2006 08:51 PM
Changing Avalon Tranny Fluid parimento1 1st Generation (1995-1999) 2 03-04-2005 04:18 PM
auto tranny fluid as engine coolant? andyman61 General Discussion 5 05-10-2004 01:36 PM
Leaking tranny fluid Slushangar Camry & Solara Lounge 0 06-07-2003 12:11 AM
