Questions on Replacing Rotors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2007, 11:30 AM   #1 (permalink)
View John5516's Photo Gallery
4th Generation Questions on Replacing Rotors
Guys,
I plan on changing my pads and rotors. I just had a couple questions on installing the new rotors. I know I have to take off the caliper, then take off the caliper mounting bracket. Then somehow manage to yank off the rotor, I saw the trick to lever off the rotors with the screws.
However when I'm putting on new rotors is there a certain way they need to go back on? Or do I just put them on? I will be doing this with a buddy, so I will have some help. Thanks for any advice or suggestions. I searched for this topic but nothing came up. I am using Brembo Blanks and Brembo Pads! Next time it will be the Hawk Pads!
John
John5516 is offline   Reply With Quote
Old 11-27-2007, 11:34 AM   #2 (permalink)
Young Toyota Tech
View Turboman412's Photo Gallery
no they do not have to go on any certain way. just make sure you clean the hub very well before you install the rotors with a wire brush or a digrinder. its actully very simple. and use anti seize on the back of the pads and the shims. and always clean off the new rotors with brake clean.
good luck
E
Turboman412 is offline   Reply With Quote
Old 11-27-2007, 07:34 PM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
good luck
E
as for the shims...I hope you mean putting hte anti-squeal lubricant on it, not anti-seize
HaHa
Old 11-27-2007, 09:52 PM   #4 (permalink)
View digmycelica's Photo Gallery
Originally Posted by John5516 View Post
Guys,
John
Here is a good tip, When pushing the caliper piston back in with a large c-clamp, unscrew the bleeder on the caliper a few turns first and put a hose on the tip. put the other end of the hose in a jar. Then you can push the piston back in without pushing the old fluid backwards back into the abs unit.It will go in the jar instead. Because otherwise you can screw up your abs system .
digmycelica is offline   Reply With Quote
Old 11-27-2007, 10:02 PM   #5 (permalink)
4th Generation
Will this apply if my car has no ABS?
Thanks!
Old 11-28-2007, 08:35 AM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Do the same with or without ABS.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 11-29-2007, 06:30 AM   #7 (permalink)
Where is this bleeder plug located?
Old 11-29-2007, 08:26 AM   #8 (permalink)
Darkside Cut Me!!!
On the caliper, top, higher than the brake hose banjo bolt fitting, it is a small 8mm hex with a nipple on top, should be covered with a rubber cap.
2004 RX330 Sport
2003 Cam I4 XLE
Gen4 brake rotors and pads replacement Luc Hardcore Tech and Competition 5 03-06-2012 03:40 PM
questions about replacing oem cat converter with an aftermarket one. ghettosled Camry & Solara Lounge 2 05-03-2006 12:10 PM
2000 camry questions dimask 3rd & 4th Generation (1992–1996 & 1997–2001) 4 03-06-2006 09:14 PM
97 Avalon Rotors parimento1 1st Generation (1995-1999) 2 05-10-2005 09:01 PM
How easy should it be to install new front rotors? Seattle206 Camry & Solara Lounge 9 03-25-2005 06:11 PM
