Hesitation when cold - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2007, 12:32 AM   #1 (permalink)
EvoFire's Avatar
View EvoFire's Photo Gallery
Yeah the car is sold... just waiting for the other guy to be free to transfer the ownership and stuff.
Anyways... since I'm still driving it, albeit very stock, it hesitates really badly when its cold. This started happening after I blew the head gasket and had it fixed. Any ideas?
EvoFire is offline   Reply With Quote
Old 11-29-2007, 02:16 AM   #2 (permalink)
EvoFire's Avatar
bump, help anyone?
Old 11-29-2007, 09:20 AM   #3 (permalink)
Intake air temp sensor?
Engine coolant temp sensor?
Idle air control solenoid?
Dirty or clogged EGR valve?
Can you get any engine codes to give you a clue?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 11-29-2007, 09:27 AM   #4 (permalink)
SLAMCAM56789
Luke4567's Avatar
View Luke4567's Photo Gallery
im haveing the same problem i think its spark plugs
Luke4567 is offline   Reply With Quote
Old 11-30-2007, 03:18 AM   #5 (permalink)
EvoFire's Avatar
No codes. Car runs perfectly after it warms up, full power through the whole rev range, its just when its cold.
Old 11-30-2007, 09:53 AM   #6 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
If, by "hesitate" you mean that it shifts later, it could be the outside temperature. The transmission oil is cold and it doesn't shift as soon. I don't think there is a fix, as such.
Kep
Old 12-01-2007, 03:07 AM   #7 (permalink)
EvoFire's Avatar
no its not that, by hesitation I mean it has no power, does not rev, and the car slightly studders.
The car is gone now.... nothing I can do anymore. No more Camry.
Old 12-01-2007, 03:47 AM   #8 (permalink)
Noob
View gladis's Photo Gallery
What do you have instead?
gladis is offline   Reply With Quote
Old 12-01-2007, 03:54 AM   #9 (permalink)
View 94CoupeV6's Photo Gallery
Sounds like a somewhat normal problem for an older car. My car runs like crap too when it's cold, so I always let it warm up past the C hash.
94CoupeV6 is offline   Reply With Quote
Old 12-01-2007, 06:45 AM   #10 (permalink)
View pigpig's Photo Gallery
could be a low tranny fluid.
pigpig is offline   Reply With Quote
Old 12-01-2007, 03:48 PM   #11 (permalink)
View sheepwundr's Photo Gallery
this maybe your probplem read my post.
Problem starting..(video inside)
sheepwundr is offline   Reply With Quote
Cold Weather Washing eddie926 Detailing & Car Care 43 12-07-2007 11:35 AM
99 Corolla - Hesitation when cold modestobulldog Archived Corolla threads 10 01-11-2007 02:57 PM
AC cold from center vents, warm on side vents 1999 XLS stehrster 1st Generation (1995-1999) 2 08-31-2006 01:37 AM
Hesitation when engine cold on 2000 CE AndrewK Archived Corolla threads 2 07-14-2005 09:30 AM
