Left Signal = RAPID BLINK // Right Signal = Normal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2007, 03:50 AM   #1 (permalink)
View FishyMan's Photo Gallery
I am kinda stressed and irked by this. I see no burnt or blown bulbs anywhere. All of a sudden, 1 day, the left signal blinker moves into rapid mode.
THe right is fine. What could it be? Any particular fuse? I will check it tomorrow.
FishyMan is offline   Reply With Quote
Old 11-28-2007, 05:55 AM   #2 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $906927
iTrader Score: 59 reviews
U do have a signal bulb that has issues. Bulbs are cheap...Not sure what yr Camry ur referring to, but My daughters 99 Gen4 had the same symptoms and I replaced the fast flashing bulb, problem solved!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 11-28-2007, 08:54 AM   #3 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
+1
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 11-28-2007, 08:57 AM   #4 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
I heard that when you get fast flashing bulbs, they are usually doing that to signal that it's at the end of it's life. each time something like that happens the next few days the light burns out.
dunno if it's true, but it appears that way.
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
Old 11-28-2007, 10:01 AM   #5 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
buy the bulb, they usually come in pairs so you can go and change both of them
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 11-28-2007, 10:08 AM   #6 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
I'm having that same problem except my Gen3 has been doing it since the curse struck me. My car is fixed, but I still have that same problem. After reading this thread I'm going to change bulbs on the whole car and see what happens...
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 11-28-2007, 11:36 AM   #7 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
that means left bulb is dying, right bulb is fine
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 11-28-2007, 12:37 PM   #8 (permalink)
View lenjack's Photo Gallery
It's a dual filament bulb. One of the filaments is faulty. So even though the bulb is lit, replace it anyway. That's the fix.
lenjack is offline   Reply With Quote
Old 11-28-2007, 04:49 PM   #9 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Some bulb styles have different "strength?" (wattage? Amperage?) even though they are all 12 volts. Go to your owner's manual and make sure that both bulbs are what they recommend. If you get two different types they flash differently. I could see where one that was getting old might change.
Kep
Old 11-28-2007, 04:58 PM   #10 (permalink)
View vdop69's Photo Gallery
My old car use to flash the front turn signal fast to tell you that the rear tail turn signal was out. gay ford.
vdop69 is offline   Reply With Quote
Old 11-29-2007, 03:54 PM   #11 (permalink)
Hi,
I forgot to say, my FRONT LEFT and REAR LEFT are doing the same thing. I'll probably change both. I gotta check the manual and hopefully they have the bulb in stock. Its' the all orange one.
I appreciate the help. I'll update.
Old 11-29-2007, 06:30 PM   #12 (permalink)
Kep
Kep's Avatar
Two bulbs on the same side doing the same thing sounds like something besides the bulbs. I am not familiar with Toyota's flasher system. Anyone know if one side is separate from the other?
Kep
Old 11-29-2007, 07:39 PM   #13 (permalink)
View Novice_cardude's Photo Gallery
I had this problem only the other way 'round. It only lasted until I got to work. At work I bought a new RF signal lamp for $.18, and I was good.
Try turning on your headlights, running lights, emergency flashers, and looking at both left turn signal indicators to see if there's a change. You could go to an auto parts store and have them look up a LF/LR turn indicator bulb and replace both to see what happens. Worst case scenario is you have a couple extra bulbs.
Only other thing I can think of is the flasher .. solenoid? forget what it is, but it regulates the speed of signal flashers. Usually affects both sides when it goes out though.
'96 4cyl 5spd Camry
147k miles and running out of things to fix...
Novice_cardude is offline   Reply With Quote
Old 11-29-2007, 08:07 PM   #14 (permalink)
Damn, today, I checked everything and the rear and even bought the orange, but when I tested it out, it was normal? WTF? This problem has been going on for weeks. But then I opened the rear LEFT and wanted to check and it was okay.
Old 11-30-2007, 10:19 AM   #15 (permalink)
Kep
Kep's Avatar
I'm sorry, but could you rephrase this? I don't understand what you did, let alone what the results were. You said that it was normal. Isn't that good? Which bulb is "the orange"? And again you said that the rear left was OK, again, isn't that good?
Kep
What do I have to do to get a left brake light on the trailer when towing??? Ron V 2nd Generation (2005+) 4 10-09-2006 05:50 PM
Left Turn Signal nitu_752002 Archived Corolla threads 4 06-30-2006 11:06 AM
1999 Camry left turn signal is rapid right is not leasure23 3rd & 4th Generation (1992–1996 & 1997–2001) 10 10-31-2005 08:41 PM
Only my left signal flashes fast, but no dead blubs!?! MortySnerd Camry & Solara Lounge 11 09-15-2005 12:35 PM
