94 4cyl No Start Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2007, 01:02 PM   #1 (permalink)
View Silver TRD Taco's Photo Gallery
3rd Generation 94 4cyl No Start Problem
My wife's 94 4cyl auto Camry w/255k miles died at a red light and wouldn't start back up. We had it towed back to the house were I started to troubleshoot. I have pulled all 4 plugs and verified that all four are firing via ground to the block. The timing belt is obviously intact, though I pulled the upper cover back to get a visual reinforcement.
So the next logical step is that its not getting any fuel right? Wrong, pump runs with key switch. I pulled the fuel pressure regulator off and cranked it, which resulted in some high pressure fuel spillage. I removed the plugs again after several failed cranking attempts to find them SOAKED in fuel.
Air + Fuel + Spark = Combustion in my book. I'm thinking the MAP sensor is bad causing too much/little fuel to be delivered to the cylinders. Anyone else had any similar issues or known problems?
Silver TRD Taco is offline   Reply With Quote
Old 11-28-2007, 01:21 PM   #2 (permalink)
crank sensor? ... there are some specs someplace in the online repair manual
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 11-28-2007, 01:26 PM   #3 (permalink)
Hmm, I suppose it could be but I doubt it. I think I'm going to the junkyard for a few sensors to play with.
Old 11-28-2007, 01:28 PM   #4 (permalink)
crank sensor is critical to engine running .... cam sensor is not.
not completely sure if engine coolant temperature is essential ...probably.
Old 11-28-2007, 01:30 PM   #5 (permalink)
Right, but this has a distributor. Does it even have a crank sensor?
Old 11-28-2007, 02:16 PM   #6 (permalink)
View toyomoho's Photo Gallery
The 94 does not have a crank or cam sensor, distributor does all the work. Check to make sure the crank/cam timing is still ok and the timing belt did not jump a few notches on the pulleys some how.
Does the engine start when you press on the gas pedal?
Old 11-28-2007, 02:19 PM   #7 (permalink)
Nope, tried holding the gas to the floor, but by then it could have already been flooded.
Old 11-28-2007, 03:00 PM   #8 (permalink)
Gameroom cash: $303055
When you verified that all 4 plugs were firing, did you see a bright blue spark or just an orange spark? Bright blue indicates a good strong spark. Orange indicates a weak spark, which can be caused by a weak coil; a common problem with these engines.
Mike
Old 11-28-2007, 04:57 PM   #9 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Try spraying some starter fluid into the air filter chamber. If the engine tries to start it suggests a problem with the fuel system. If it doesn't try to start it suggests an electrical problem. This is by no way fool proof but it is helpful. If you use either be very sparing.
Kep
3VZE Intemittent problem, hard to start mxben 89-95 Toyota Pickup/Hilux 8 11-18-2007 10:53 AM
Recaros Start seats are now just $195.95! Buy last years close out fabrics and save! Safe Drives Supporting Vendor Sales 0 11-09-2005 07:17 PM
94 Lexus ES300 Starting Problem starry012 General Lexus Discussion 0 10-03-2005 01:21 PM
Need help asap. No start problem. kieran1094 Archived Corolla threads 2 07-28-2002 10:48 PM
94 Camry cold start problem Tushy 3rd & 4th Generation (1992–1996 & 1997–2001) 3 06-21-2002 12:58 AM
