Removing passenger door panel on my 92 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2007, 10:30 PM   #1 (permalink)
View shibity's Photo Gallery
Hey guys, this is my first post on the forum.
I need to replace my passenger side mirror. It looks pretty simple, just pop the cover off the door, unscrew the mirrow and unplug the electrical. the only problem is i can't get the door panel off to get to it. I unscrewed it and everything. but it still wont budge. Any ideas? Thanks!
shibity is offline   Reply With Quote
Old 11-29-2007, 11:03 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
the trick is that you have to kind of yank the bottom out and then pull upwards on the door to slide it up and out
HaHa
Old 11-29-2007, 11:13 PM   #3 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
Are you sure you need to remove panel to replace mirror? Mine are powered. Carefully pry the black plastic off from the inside, remove screws and work wire connector up to disconnect. It's been a while but pretty sure I didn't remove panel. (BTW, there's a screw hidden behind the red marker light if removing panel.)
Dave's is offline   Reply With Quote
Old 11-30-2007, 11:57 AM   #4 (permalink)
Gameroom cash: $303055
I recently did this on my 94. it should be the same as your 92. Like Dave's says, you shouldn't have to remove the entire door panel to change the miror. Just pop off that black triangle piece behind the mirror and the rest is as Dave's described. This is a 5 minute job, off and back on.
Mike
92 Corolla Engine Removal blb 6th Generation (1988-1992) 6 04-09-2011 05:11 PM
clear corner for 92 CamryOwner98 Tercel, Paseo, Starlet, and Sera Forum 2 05-23-2008 09:50 PM
WTB 92 Celica Passenger side mirror King_Mack Car parts for trade or wanted parts 2 08-04-2007 06:00 PM
92 Camry Stereo Bracket Install Mania!!!! FarmerJ Audio, Video, and Security - Tech 3 03-28-2007 04:30 PM
Removing 92 radio... jbrdbr111 Archived Corolla threads 6 11-09-2006 12:04 AM
