I have a 1999 Camry 2.2L 4 cyl. automatic and have been having
start up problems for a few weeks. The car does not always crank at start up. The problem was sporadic at first but seems to have gradually gotten worse. Almost every time the car is started, I have to shift the gear from Park to Drive/Neutral/Reverse and go back into Park, sometimes multiple times before starting successfully. From what I have read, it appears that the problem is in the park-neutral (or neutral-safety) switch. Where exactly is this located? I have both Haynes and Chilton manuals but they don't have decent photos/description.
A photo had been posted in one of the threads some time ago. I am having trouble seeing it and would appreciate someone posting it again!
As far as the switch itself, is an adjustment all that's typically required or is it common enough for the switch to go bad? These switches are not cheap to replace as I am finding out!
Thanks for all the help.
S.
