Ok, I am sSick and tired of people responding to threads with misleading and incorrect info. SO READ!!!! So next time a New Member askes a question on it, simply refer them here, so
they get the correct info!
O/D Dont’s:
1: O/D off during acceleration is retarded, end of story.
2: O/D off during cruising, or just normal driving, IS STUPID, period.
O/D Do’s:
1: O/D off should be used with the anticipation of passing at highway speed. It gives you that split second more power (Not needing to downshift) for the pass.
2: O/D off should be used if going up a steep hill at highway speeds where you start to loose speed.
ECT Don’t’s:
1: Normal Acceleration with PWR on. If your accelerating normal, why in hell would you have PWR on? Dumb.
2: Normal Driving. Read above.
3: WOT with PWR. See video’s below. NO DIFFERENCE!!!!!!!
ECT Do’s:
1: Heavy Acceleration but not at WOT. PWR will have it shift at a higher RPM for a smoother and faster acceleration.
2: Heavy traffic. I.E., New York City highways. PWR causes the tranny to downshift to a lower gear, at a higher RPM, for a MUCH faster acceleration. See video's below.
ECT PWR and O/D OFF
1: Ok, just see video below and look at RPM's and maybe you'll see why your MPG is so bad.
REV Limiter Discussed:
1Q: Will hitting the Rev limiter cause my engine to explode?
1A: No, it will not. The Rev Limiter (6750 RPM’s on the 1MZ Gen 3) is there to PREVENT damage. If it would cause damage, the limiter would be set lower.
2Q: What does the Rev Limiter sound like?
2A: See video below.
3Q: Since hitting the Rev Limiter is not going to kill the engine, can I do it all the time to look cool?
3A: Yeah, but enjoy looking like a Tool when you end up doing it so many times, you DO kill the engine. Redline is there for a reason ya know! It’s normally ok once in a while* but not all the time.
* Disclaimer, If you blow the engine, TN nor any members are responsible for your stupidity. In no way is it good to hit the Rev Limiter, or recommended in any way. Under most circumstances, it does not hurt, but still should not be done.
WOT with OD on and ECT normal
WOT with ECT power and OD off
Flooring at 32mph with ECT normal
Flooring at 32mph with ECT power
REV LIMITER
