po401 is low flow. check where the egr connects to the intake and make sure there isnt a wall of carbon blocking the hole. if there is just clean it out and you should be fine. shouldnt have to replace any parts.
I still dont see what you have pictured in the first picture in the second picture. I see things that look similar...but they are not what you have pictured.
Are the EGR valves on our cars different from model to model or something?
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
the first picture isnt from a Camry ... its just what an EGR valve/system looks like .... the 2nd picture is an actual 5S-FE
R.I.P. '95 Camry LE | Welcome "Blurple" '96 240SX SE Buy My Weapon-R Intake [Here] http://sck388.mybrute.com
If you pull off the hose on the EGR valve and take a vacuum pump and attach it to the Egr valve. With the engine running, pump up the vacuum pump . If the engine stalls or stumbles then your Egr valve is ok and the port is not clogged . If this is the case replace the egr modulator and the electric vacuum solenoid which is mounted on the back side of the motor block under the intake.
This will fix your problem
on the imz the egr is right next to the throttle body. it would be where the intake goes from single tube to all six. inside part of the sweeping turn of the intake. if you put your hand on the throttle body move your hand about 3-4" to the left and your hand would be on the egr. the picture of the egr in the thread is off a 5sfe but looks kind of like that as well on the 1mz.
people read before you answer. he is talking about a v6 not 4 cyl. the part of the egr system that is creating the low flow problem is not the egr itself, it is where the egr attaches to the intake manifold. carbon builds up a wall right there creating low flow from the exhaust to the intake. your egr valve will still work it is just being restricted by the wall of carbon at the intake. the vsv you speak of on a v6 is actually on the fuel rail next to 2 other vsv valves. if that was not working you would get po402 for no flow.
