Removing A/C? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2007, 01:28 PM   #1 (permalink)
boombringer's Avatar
View boombringer's Photo Gallery
3rd Generation Removing A/C?
Has anyone removed the whole A/C system? I want to remove it as It probably weights allot and I don't use it, and I plan on stripping my car down.
Does anyone know how much it weights total? And how hard it is to remove?
Thanks for any help.
boombringer is offline   Reply With Quote
Old 12-01-2007, 01:58 PM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Man it cant weigh THAT much to make it worth taking out. The heaviest thing is the compressor and that doesnt even way too much.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 12-01-2007, 02:04 PM   #3 (permalink)
3rd Generation
But you take that out the tubing and everything, the back seats, the carpet, everything else and you got some weight out. And I'm replacing the two front seats with light racing seats. Also when someone else rides in my car I can feel the difference from the extra weight. So losing 100+lbs I should be able to feel that also.
Old 12-01-2007, 02:14 PM   #4 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
^ FYI - The rule of thumb is that for every 100 lbs you remove you only gain 0.1 sec on the quarter mile.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 12-01-2007, 02:18 PM   #5 (permalink)
3rd Generation
You know I don't believe in thumbs
Old 12-01-2007, 03:11 PM   #6 (permalink)
View toyomoho's Photo Gallery
For Gen_3 and 4 pretty sure your will need to remove the dash to get at the evaporator, this is a LOT of work. Suggest removing the A/C compressor, condenser, etc. Save the parts in case you sell the car.
You will also need to deal with the electrical side of the A/C system such as A/C amplifier, idle up system, etc.
The link below provides access to service manuals.
http://www.camrymanuals.com/
Old 12-01-2007, 03:27 PM   #7 (permalink)
Thanks.
Help: Removing stain from a/c controls behind clear window *wishlist* 5th & 6th Generation (2002-2006 & 2007-2011) 5 04-18-2007 08:27 PM
removing a/c htr controls GEN4 MemphisR 3rd & 4th Generation (1992–1996 & 1997–2001) 3 03-07-2006 09:43 PM
removing trim around the radio and a/c Anh Tung Camry & Solara Lounge 9 08-10-2004 03:56 PM
NEED HELP removing a nub off the a/c controls fallennite Camry & Solara Lounge 3 04-24-2003 08:46 PM
Removing A/C from the belt route on V6 DS - TTCC General Discussion 9 02-06-2002 10:31 AM
