There is a green wire with a red stripe in the trunk area, which powers the rear two stop lights .... inspect for bare insulation and general integrity. There is also a solid red wire that goes from the light failure sensor to the high mounted stop light in the back window.
If not either of these two wires, then it is possible that there is some sort of internal short within the stop light sockets .... If you are blowing fuses when you check the suggested items, you can use a suitable multimeter .... amps mode ..... to temporarily jump across the stop fuse .... just keep a close watch on it and don't allow any sustained short circuits.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
