Spark Plug boot trouble; 5S-Fe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2007, 07:42 PM   #1 (permalink)
youngflashycamr's Avatar
View youngflashycamr's Photo Gallery
3rd Generation Spark Plug boot trouble; 5S-Fe
hello all! i was i n the proces of doing a tune up today when i came across a little problem...those of you with the 4 cyl may have already come across this. while removing the boot( after the engine had cooled for a few gours) the last inch pf the boot stayed in the shaft, u kno that fatpart on the end that makes it a vaccuum.. how would one go about removing this boot...cuz as of now i am without automobile...a friend of mine with a 5SFE mr2 said that there's some kind of tweezer/fish-hook deal that can pull it out easy
i like having had lulz.
also, shares his name with the first civic i got laid in.
AIM: imeffindash
Originally Posted by Venom_5 View Post
everyone IS entitled to an opinion .... yours is just wrong
youngflashycamr is offline   Reply With Quote
Old 12-02-2007, 08:32 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
This happens a lot, and happened to me too. What I did was straiten out a coat hanger and use it to cut up the boot a little so that it was in a couple pieces, then I duct taped a straw to a vacuum cleaner and used the suction to pull the pieces out. If you can find tweezers long enough to reach in there you can do that too.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 12-02-2007, 09:07 PM   #3 (permalink)
View gonesurfing's Photo Gallery
I think I used a long pair of needle nose pliers. It's happened to me at least once on two different Camrys.
gonesurfing is offline   Reply With Quote
Old 12-02-2007, 10:31 PM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I used a wire coat hanger with about a 3/8" piece at the end bent to a right angle. I wedged the end into the rubber boot and tugged in three or four places until it came loose and pulled out.
Kep
Old 12-02-2007, 10:36 PM   #5 (permalink)
View digmycelica's Photo Gallery
If you cut a piece of wire like a coat hanger to about 12 inches. Sharpen one end like a toothpick then bend it about 1/4 inch up to a 90 degree angle on the sharp end. you can run that in the hole and stab the rubber suction boot and pull it right out.
digmycelica is offline   Reply With Quote
Old 12-02-2007, 11:30 PM   #6 (permalink)
joy!!! this gon be fun cuz im not good with sharp objects!!
AIM: imeffindash
Old 12-03-2007, 10:09 AM   #7 (permalink)
Kep
Kep's Avatar
Try it without sharpening it first. Just cutting the coat hanger with wire cutters puts a pretty mean edge on it. If it doesn't grab, then sharpen it.
Kep
#2 Spark plug not seated in head... boostedbrick 89-95 Toyota Pickup/Hilux 4 11-10-2007 11:24 PM
Spark Plug Lead???? 94_v6_camry 3rd & 4th Generation (1992–1996 & 1997–2001) 2 05-03-2007 11:15 AM
Blown Out Spark Plug ripsnub Pre-88 Toyota Pickup/Hilux 1 04-19-2007 06:06 PM
spark plug wires... help 90yotapickup 89-95 Toyota Pickup/Hilux 18 02-21-2007 09:20 PM
