You shouldn't have drained the pan in your Volvo. Probably didn't hurt, but it's not recommended (until a month ago I had a '93 945T).
And to do the flush in your camry... disconnect the transmission line to the transmssion at the radiator, and do the driver's side one. Connect the 5/8" ID hose to it (the same hose you used on your Volvo). Start the car. As fluid pumps out, be adding fresh fluid into the automatic tranmission fluid dipstick via a transmission fluid funnel.
Keep track of how much fluid is leaving by having it pumped into gallon jugs, gallon jugs on which you have pre-marked quart lines. Have three or four bottles of transmission fluid already opened and ready to go. At some point, with your foot on the brake, work your way through the gears for a few seconds each. Really, it's the same routine as you did on your Volvo except don't drop the pan and use the driver's side hose to the transmission.
