2000 rear rotor removal help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-03-2007, 08:57 AM   #1 (permalink)
View srwhouston's Photo Gallery
Have a 2000 XLE model, I am trying to get the rear rotor off. Can anyone help me here? What tool do I need to seperate it, or get it off. It is stuck on good
srwhouston is offline   Reply With Quote
Old 12-03-2007, 09:32 AM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
You probably need to retract the parking brake shoes so that they are not interfering with the inner drum.
Aside from that, use rust penetrating oil on the lugs and lug holes if that is where you have rusted so badly that it is seized.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 12-03-2007, 09:36 AM   #3 (permalink)
I released the brake gear through that little hole until it wouldnt go anymore. Still couldnt get the sucker off
Old 12-03-2007, 09:37 AM   #4 (permalink)
Darkside Cut Me!!!
But the rotor spins freely and the caliper and holder is out of the way right?
2004 RX330 Sport
2003 Cam I4 XLE
Old 12-03-2007, 09:38 AM   #5 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
there are two holes on the rotor, you can try use the caliper screws in those two holes and turn the screws evenly to push it out, also you may try use force, put a piece of wood stud on disc surface, and get a 12lb hammer and hammer the wood stud, it should come out eventually.
bronzemaxell is offline   Reply With Quote
Old 12-03-2007, 09:40 AM   #6 (permalink)
yep
Old 12-03-2007, 09:41 AM   #7 (permalink)
So it just sounds like it is stuck, nothing special other than some lube and hammer time is needed I guess
Old 12-03-2007, 02:14 PM   #8 (permalink)
Gameroom cash: $303055
Don't use a hammer unless it is absolutely necessary. Use 2 corresponding screws in those 2 screw holes to lever the rotor off, as bronzemaxell pointed out. That's what they are there for. The rotor is rusted to the hub. It will come off that way. You will probably hear a pop sound when it breaks free.
Mike
FS: 2000 Toyota Celica GTS Turbo Showcar R0ME0 Vehicles 11 05-03-2009 10:36 AM
Rear Locking Differential Question GEORGIA-BOY 2nd Generation (2005+) 11 11-22-2007 08:33 AM
Brake Noise FirstCamry 5th & 6th Generation (2002-2006 & 2007-2011) 7 10-30-2007 02:40 PM
align it fredk 1st & 2nd Generation (1983–1986 & 1987-1991) 2 06-18-2007 09:48 PM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
