Erratic idling in 1999 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-03-2007, 08:30 PM   #1 (permalink)
View 99camryLE's Photo Gallery
4th Generation Erratic idling in 1999 Camry
This problem started a few days ago. I have a 99 camry LE, 95K miles, 4 cyl, auto tranny. When I try to start it, the car would idle very very low, then sometimes the RPMS would drop down and it would stall out. If I give it gas for a few minutes to keep the RPMS up, the RPM needle will eventually jump up and it will run fine...no problems while driving or if I stop and start again. Afte rit starts, the car runs perfectly. This happens every morning and at night, after I get out of class. I think it might be the idle start valve that needs cleaning, but I'm not sure. Any ideas?
Its not what u drive, its how u drive it!
99camryLE is offline   Reply With Quote
Old 12-03-2007, 08:37 PM   #2 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
You're on the right track. Start with cleaning out the idle air control motor and go from there.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 12-04-2007, 11:32 AM   #3 (permalink)
Thanks Qslim. Is there anyhting else I should do besides clean the IAC valve?
Old 12-04-2007, 08:18 PM   #4 (permalink)
View merenjay's Photo Gallery
Clean the EGR valve. Sometimes they stick due to carbon build up.
merenjay is offline   Reply With Quote
Old 12-04-2007, 08:43 PM   #5 (permalink)
Qslim's Avatar
Sticking EGR valve generally present a problem during operation, not just at startup. A classic symptom of a bad valve is stalling when coming to a stop, as the EGR valve doesn't seat well after having opened during cruising.
-- Get him, boy....
Techna-fit Brake/Clutch Line Group Buy: All Makes/Models raptorracing Supporting Vendor Sales 230 08-27-2007 12:22 AM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
2002 - 2005 Toyota Camry review! Lexusfreak 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-27-2006 03:43 AM
