had the same exact problem a few weeks ago, brake lights didnt go on/couldnt shift out of Park, the STOP fuse blew out, here's how you can fix it:
1) next to the base of the steering wheel to the left, there's a pocket to store coins/etc, take out that pocket
2) turn the pocket around, it has a guide to all the fuses inside, look for the STOP (15A) fuse, 2nd column & next to last on the bottom
3) get a plier to pull out the fuse, check it, its probably blacked/blown out
4) get another 15AMP fuse and plug it back in the same spot
this will fix the problem
first time this happen it was a pain, then it happened 2 weeks after, then it happened again last weekend (where i went through at least 10 fuses in 2 days), finally realized i had a short circuit in one of my wires in the trunk, you may want to double check your wires if this happens more than once
