1998 Front End Rattle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2007, 09:46 AM   #1 (permalink)
View doolitt3's Photo Gallery
I just joined the forum. Has there been discussion of front end rattle noise on 1998 Camry? My mechanic can hear the noise, but can't find the cause. Struts have been replaced.
doolitt3 is offline   Reply With Quote
Old 12-05-2007, 01:45 PM   #2 (permalink)
Radio, this is Unit 91...
eurohazard's Avatar
View eurohazard's Photo Gallery
I have the same thing. When I changed my struts everything looked ok. But I am sure it's my passenger side strut mount (above the strut itself) that is the culprit on my Camry. I just haven't had time to get up in there to change them.
Did your noise occur right after the struts were changed?
1993 Camry LE 5SFE AT, 2006 Nissan Armada LE 4x4, 1971 Cadillac Coupe DeVille "pimp juice"
Toys: 2007 Coachmen 19FLB, 2007 Regal 1900 V6
I'm the biggest boss thatchu seen thus far! Baby, that's muh wi'zzard!
eurohazard is offline   Reply With Quote
Old 12-05-2007, 01:50 PM   #3 (permalink)
JvR
JvR's Avatar
View JvR's Photo Gallery
When you make a corner?
I have the same problem, it is te cv joint
JvR is offline   Reply With Quote
Old 12-05-2007, 02:05 PM   #4 (permalink)
eurohazard's Avatar
Mine happens when the front end goes over a bump. A lot of times bad CV joints are described as a popping, clicking, or grinding sound while turning.
Old 12-05-2007, 02:11 PM   #5 (permalink)
Noise came after struts replaced. Mechanic who installed struts can't find the reason for the noise. Says everything is "tight." I know nothing about the science of auto mechanics. I just change the oil when I'm supposed to. I've been reading on the web about others with a strut mount (whatever that is) problem. This is frustrating. Haven't taken it to a Toyota shop yet. Think they'll be able to figure it out?
Old 12-05-2007, 05:22 PM   #6 (permalink)
Gameroom cash: $303055
It is most likely the upper strut mount. Toyota had a problem with those on the 97-99 Camrys. The replacement is a redesigned mount. Do a search for "strut mounts" on this forum and read up on the problem. It has been discussed many times.
Mike
Old 12-05-2007, 07:15 PM   #7 (permalink)
4th Gen Camry Owner
View kpszar's Photo Gallery
Mike
I bought new OEM and After market strut mounts and it still have problems. I did the hole suspension, I don't think it is the strut mounts.
kpszar is offline   Reply With Quote
Old 12-06-2007, 02:09 PM   #8 (permalink)
Remember I said it's "most likely" the upper strut mount. There are other things in the front that can cause rattles, like the sway bar end links and the sway bar bushings, just to name 2 other things that can cause rattles when they wear/fail. These would be the next most likely things I would check.
Mike
Superpro/Whiteline Group Buy due to North America wide Price Increase raptorracing Supporting Vendor Sales 51 07-22-2009 11:12 AM
Lexus IS Pricing (Canada) lexusis350 Toyota News 28 10-01-2007 11:30 AM
Rebuilding the front end Sniperdude 3rd & 4th Generation (1992–1996 & 1997–2001) 14 08-13-2007 02:11 AM
Weird front end sound and rear rattle BABAROGA 2nd Generation (2005+) 0 01-26-2007 09:46 PM
Susp. mods - Front End Noise is Gone dj14901 Camry & Solara Lounge 10 07-01-2006 05:49 AM
