I had an O-ring of an injector leak and had a similar problem. It was most noticeable in the morning, after sitting for a while. I figured that the bad seal allowed air to seep in and then the gas in the line would drain back into the fuel tank. Evidently it leaked when the engine was running as well because I could smell gas and the area around the injector was real clean. I would suspect that your O-ring was scratched when it was replaced.
Kep
