Draining - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2007, 04:56 PM   #1 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
Draining
I just noticed this the other day after washing my car. I opened the back right door, and there was water inside the weather stripping on the body. Not the piece attached to the door itself, the piece attached to the body. If I press on that weather strip the water comes out the holes on top of the weather strip. I've never noticed this before and it doesn't seem to happen on the other doors. Is that normal, or is it an indication that there's a drain hole plugged up somewhere?
eddie926 is offline   Reply With Quote
Old 12-06-2007, 05:27 PM   #2 (permalink)
View toyomoho's Photo Gallery
The lower inside portion of the door has little rubber check valve plugs. This plugs act as a one-way valve to drain water from the inside the door. Try prying the bottom of the plug open a little and see if water drains out. If plugged use a rod or something to clean the area.
92 previa a/c draining all my coolant vwfreaks Previa Forum 10 09-26-2007 06:39 PM
HELP something draining the battery awinter 89-95 Toyota Pickup/Hilux 9 08-15-2007 09:18 PM
Batteries are draining BCinBC Archived Corolla threads 0 11-21-2005 04:52 PM
Non factory alarm draining battery? 03 CE Corolla... Please help latstar Archived Corolla threads 3 01-28-2005 07:11 PM
