little help please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2007, 06:24 PM   #1 (permalink)
View nick3538's Photo Gallery
little help please
ive done a lil research but no luck.
Is it possible to use the 5 speed transmission out of the 4cyl motor
and put a v6 in, and use the 5 speed trans?
nick3538 is offline   Reply With Quote
Old 12-05-2007, 07:12 PM   #2 (permalink)
View SmartedPanda's Photo Gallery
You can do anything, and everything. The real question is why would you?
1992 Camry. 4dr Sedan. 3rd Gen.
2.2L 5S-FE I4, with ~167K Miles.
Trying to get my baby restored...
So Far: Dual XHD-6425
SmartedPanda is offline   Reply With Quote
Old 12-05-2007, 07:15 PM   #3 (permalink)
i just want a v6 motor, I love the 22r motor its so damn reliable. But I want a stick v6.
will the tranny bolt up? and what all will it take?
from what ive read, the v6 didnt come in a stick in the 3rd gens.
Old 12-05-2007, 07:20 PM   #4 (permalink)
View J_Phu's Photo Gallery
The gen 3 did come with standard v6, but they were rare. Why don't you use the E135 transmission its way stronger than what you're planning on using
J_Phu is offline   Reply With Quote
Old 12-05-2007, 07:23 PM   #5 (permalink)
wat about the mounts and axles and wiring harness
Old 12-06-2007, 12:59 AM   #6 (permalink)
Yeah you're going to need transmission mounts and new cv axles...pedals, clutch etc etc. Ecu....not necessary, but you can if you want. As goes for harness, all you need is the reverse light. And you would have to connect the park/safety switch together so your car would start.
Old 12-06-2007, 01:06 AM   #7 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
if u want a V6 5 speed then either buy one or buy a junked car with both and swap the tranny and the engine at the same time. its alot of work and money unless u do the labor ur self then ull save a bundle. search around though, there are hundreds of posts about swaping a manual, V6 or V6 manual. ill give ya this though, it may help a little.
http://www.toyotanation.com/forum/t204270.html
http://www.1jz.com/camry/guide-trans.htm
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 12-06-2007, 05:30 PM   #8 (permalink)
I have a 5speed trans in my car already. I was just hoping i could use my tranny and that motor.
