Timing belt replacement 1997 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2007, 04:13 AM   #1 (permalink)
View tommyjohn's Photo Gallery
Can anyone tell me what the timing belt replacement schedule is for my 1997 Toyota Camry it was replaced at 60.000 miles that was before i bought the car the current mileage on the car is 137.146. Is there a specific schedule for this replacement.
tommyjohn is offline   Reply With Quote
Old 12-07-2007, 07:06 AM   #2 (permalink)
View 1996camry's Photo Gallery
mine 96 toyota camry has timebelt interval 60,000...i think 97 up has interval 90,000...u can call dealer just ask a ?...they tell u.....but if i remember right..toyota 97 has 90k timebelt interval...with year 97 up..the timebelt interval has 90k...
year 96 and below..has interval 60k for timebelt interval
my car just done a timebelt changed on my toyota 96 camry 4 cylinder....i went over 2000 (recommended 60k to changed) and when i changed new timebelt...the old timebelt is still in good condition...if u worry your belt break...this can give u a comfort....if u go over 2k-5k without a problem...but just plan to change belt soon....
1996camry is offline   Reply With Quote
Old 12-07-2007, 01:38 PM   #3 (permalink)
Gameroom cash: $303055
60,000 miles on the generation 3 (1992-1996) and 90,000 miles on the generation 4 (1997-2001) is correct. Your 97 should be due for it's next timing belt change at 150,000 miles.
Mike
Old 12-07-2007, 07:09 PM   #4 (permalink)
Timing belt replacement 1997 camry
Thanks guys i called two different Toyota dealers and they want me to bring my car in for inspection instead of just telling me the interval for changing the belt.
Old 12-07-2007, 09:40 PM   #5 (permalink)
View lenjack's Photo Gallery
90,000 is right.
lenjack is offline   Reply With Quote
Old 12-08-2007, 02:21 PM   #6 (permalink)
Of course they do; they can't sell you anything on the phone. They also can't charge you an inspection fee on the phone. Remember, their job is to make money for the dealership and for themselves.
Mike
Old 12-08-2007, 06:37 PM   #7 (permalink)
02
JMSinMD's Avatar
View JMSinMD's Photo Gallery
Interval
I've heard the same 60k for 92-96 and 90k for 97-01 but in reality they are all the same 2.2 I4 5S-FE using the same part numbers for the timing belt. I'd say 90k for all the years. I've seen some (less than 5) break before 90k, and I've seen them with 110k and not break. 90k is preventative.
JMSinMD is offline   Reply With Quote
Old 03-16-2008, 03:35 PM   #8 (permalink)
View Uncle-Enrico's Photo Gallery
Do low milage timing belts age?
I have a 97 Camry with just 50,000 miles on the original timing belt.
Should I be concerned with the age of this belt? Eleven years?
Also, is this four cylinder engine the type that would get damaged if the belt broke?
Uncle-Enrico is offline   Reply With Quote
Old 03-17-2008, 09:27 AM   #9 (permalink)
View nikita's Photo Gallery
According to the dealer, and a few independents, Toyota engines are non-interference, meaning if the belt fails, there is no damage. I changed the belt on a Corolla that had stopped running due to a worn out belt and there was no collateral damage.
nikita is offline   Reply With Quote
Old 03-19-2008, 07:28 PM   #10 (permalink)
View llcoolpass's Photo Gallery
not all toyota engines are non-interference.
some are, some aren't. the newer v6 for instance with the sophisticated variable valve timing is interference.
the 3vz-fe is a non-interference tpye of engine, though
1993 Lexus ES 300 [completely stock] -- 5-speed Manual V-6 3VZ-FE -- Curb Weight 3,570 lbs; Mileage 152,000 -- 0-60mph http://www.youtube.com/watch?v=ygwUh1MZRLM
llcoolpass is offline   Reply With Quote
Old 03-20-2008, 04:07 PM   #11 (permalink)
Here's a site that will tell you which engines are interference type and which are non-interference. It has most car makes and models listed.
http://www.gates.com/downloads/downl...older=brochure
Mike
Old 03-21-2008, 10:34 PM   #12 (permalink)
that link doesnt work proper
Old 03-21-2008, 10:39 PM   #13 (permalink)
Don't get mad. Get even.
El Tano's Avatar
View El Tano's Photo Gallery
LY.....
El Tano is offline   Reply With Quote
Old 03-21-2008, 10:54 PM   #14 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Most Toyota engines with timing belts are non-interference. Those with chains are interference engines. The 3MZ-FE (3.3L V6) is a recent example of an interference engine with a belt. I'm sure there are a few more though.
2007 Camry 2.4L 5M
Old 03-21-2008, 11:00 PM   #15 (permalink)
View camryvibe's Photo Gallery
I have a '97 Camry I-4 and the maintenance manual that came with the car does *not* indicate that replacement of the timing belt is a scheduled maintenance item *except* for vehicles used in commercial applications involving extensive idling time. In that case the manual specifies every 60,000 miles. However, the previously mentioned suggestion of 90,000 miles seems like a reasonable interval to be fairly safe. The belt on ours lasted for 144,500 miles and I can confirm that it is a non-interference engine.
So I'd expect that you can go to at least 150 kmiles before doing the replacement. Note that the waterpump is located in the same area so it's almost no additional labor to replace it at the same time. And the belt tensioner frequently starts wearing out and making some noise around the time of the second belt change so that could also be changed. We had some oil leakage from the crank and oil pump seals so those were replaced at the same time as the belt.
camryvibe is offline   Reply With Quote
My Timing belt change (very detailed, pics) Gen 4 JerryGiese 3rd & 4th Generation (1992–1996 & 1997–2001) 166 04-09-2012 10:44 PM
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
1997 Timing Belt Replacement DanMaryAnn 1st Generation (1995-1999) 8 11-29-2006 04:42 PM
Timing Belt Replacement done, but... help and advice needed blueskyhding 3rd & 4th Generation (1992–1996 & 1997–2001) 5 05-14-2006 08:24 PM
