Valve Cover Tubes? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2007, 01:33 PM   #1 (permalink)
masteryota1's Avatar
View masteryota1's Photo Gallery
Valve Cover Tubes?
Hi, i finally got took my 1995 Camry v-6 to toyota dealership for transmission fluid drain and fill. Well since buying the car in may/june its the first time i have had them look at it.
Ok Now i have had 2 oil changes at the "mechanic" (not toyota dealership) who I usually take cars to. Each time i try to have him find where the small leak is coming from, and never got a clear answer. ATLEAST THE TOYOTA dealership people gave me an answer, not sure if its the only source of leak, but they said it was a leak at the valve cover tubes. The price for repair wasnt too pretty, but it wasnt something major I had to do right away. I just need to make sure i watch fluid levels on weekly basis, and i do that already.
Wanted to know if this is a common leak in camrys and if there are leak treatments that might work, or what is average price to have something like this repaired.
masteryota1 is offline   Reply With Quote
Old 12-07-2007, 02:58 PM   #2 (permalink)
View digmycelica's Photo Gallery
I think the average joe should not even attempt to replace the valve cover gaskets himself. You have a heck of a lot to remove to get to the back cover. It will take a good 6 hours to do both covers and that's if you are skilled maybe more if you figure in a lot of clean up time. you could expect to pay close to $400 pretty easy. yes this is pretty common. valve cover gaskets and plug seals get pretty hard over time.
Last edited by digmycelica; 12-07-2007 at 03:00 PM. Reason: though of more i wanted to say
digmycelica is offline   Reply With Quote
Old 12-07-2007, 04:06 PM   #3 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
uuhh....what are YOU smokin!?! Valve cover gasket replacement is like the EASIEST thing to do on a car!
Please...please tell me you're mistaken the head gasket for the valve cover gasket!
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 12-07-2007, 04:11 PM   #4 (permalink)
only because i dont know, is valve cover tube, and valve cover gasket the same thing? the dealership wanted too freakin much, for me to pay right now. like $749 over $800 after tax i think. That is something that is going to have to wait, especially since the people who had car before i got it, some reason there was no date on the timing belt. so i will probably go on and have that changed in january or feb that price is about $425
Old 12-07-2007, 05:30 PM   #5 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
They are not exactly the same thing but (if I understand this right) the tubes are screwed into the head through the valve cover and hold it (and it's gasket) down. These tubes are where the spark plugs are located and have their own seals/gaskets. Thus you probably would be wise to replace all at the same time. The head gasket is something all together different. It's between the head and the engine block. (If I'm a complete moron on this I'm SURE someone will be glad to set the record straight post-haste).
Dave's is offline   Reply With Quote
Old 12-07-2007, 06:14 PM   #6 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
valve cover gasket on 4cyl 2.2L is easiest
but i believe he has a V6, there are two valve cover gasket, front one is easier, the rear valve covergasket is a b!tch, took me a good 4 or 5 hours at my slow pace to do it right.
bronzemaxell is offline   Reply With Quote
Old 12-07-2007, 06:27 PM   #7 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
^ yup the one on the back is a pain. so if your gonna get that far mind as well change the plugs (just my opinion though).
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 12-07-2007, 07:53 PM   #8 (permalink)
Easiest on a v6 camry? What are you smokin? You have to pull the top half of the intake with egr pipes, wire connectors, they even run a large electrical wiring harness on top of all that. . We're etalking a v6 not a simple 4 cyl.
Old 12-07-2007, 08:00 PM   #9 (permalink)
You really don't mess with the tubes themselves, when you pull the valve cover, you will see 3 seals on the bottom side of each cover. all you do is pry these seals out & clean everything & put 3 new seals in place of the ones you removed then put the valve cover gasket in and apply permatex to the corners then install the cover back.
Old 12-07-2007, 09:25 PM   #10 (permalink)
View cloudsearch's Photo Gallery
I probably have the same leaking problem here with a 97 I4. Just wanna ask if this is easy or hard...as there has been different arguments in this post.
cloudsearch is offline   Reply With Quote
Old 12-07-2007, 09:26 PM   #11 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
It is easy for the I4, but hard for the V6.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 12-07-2007, 09:45 PM   #12 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
a valve cover gasket replacement is quick & easy on the 5S-FE (engine code for the 4 cyl)
the front cover is easy on the 1MZ-FE (V6), the rear is harder ... but still not difficult, just takes a while
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 12-07-2007, 10:38 PM   #13 (permalink)
Dave's
Well, I've been told one of my I4's has a leaking tube so to fix it do I remove the valve cover or can I just remove the tube?
(Sorry to jack the thread but I'm sure this could help others here.)
Old 12-08-2007, 06:38 AM   #14 (permalink)
Just remove the valve cover and replace the 4 seals that are mounted to the under side of the cover. It the tube itself has a hole in it or something I don't know for sure if they can be removed. either way though, the cover has to come off.
Old 12-08-2007, 10:36 AM   #15 (permalink)
My point is..is that it's not HARD...it's just time consuming. There is NO need to pay that kind of money for someone to change a valve cover gasket. And yes..I know he is talking about a V6. Still...not hard..just time consuming.
Dropped a small piece of pcv valve grommet in valve cover sk72 3rd & 4th Generation (1992–1996 & 1997–2001) 4 11-12-2007 08:52 AM
Re: Valve cover gasket set on 4AGE Kevs Toy Archived Corolla threads 4 01-17-2007 02:21 PM
best valve cover gaskets for '97 V-6 Robert K 3rd & 4th Generation (1992–1996 & 1997–2001) 9 01-05-2007 06:10 PM
