Trouble with Diff Plug on 1997 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2007, 05:42 PM   #1 (permalink)
View bmmgolf24's Photo Gallery
The other day I went to change the diff fluid in my 1997 Camry. The Fill bolt came off without a problem; however, I was unable to get the drain plug off. The previous owner must have messed around with the plug. The hex pattern is rounded off, which does not allow for the 10 mm hex bolt to be used.
Does anyone have any advise on how to get this plug off? Obviously if I have to ruin the plug, I need to have a replacement any advise on this?
bmmgolf24 is offline   Reply With Quote
Old 12-07-2007, 08:11 PM   #2 (permalink)
There is a particular type of punch tool .... called a 'prick punch'. It has a hardened, sharp point. If you hold the punch at an appropriate angle, 45 degrees or so, and place it at the outer perimeter of the flat portion of the drain plug, you should be able to loosen the plug with several good hammer blows. The sharp point will grip the surface of the plug. Hammer the punch at two or three different locations around the perimeter of the plug. ...
When you finally get the old plug out, replace with a new one.
If you try this technique, and it doesn't seem to be working, you are probably tightening, rather than loosening the plug.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 12-07-2007, 09:49 PM   #3 (permalink)
J.Vincent's Avatar
View J.Vincent's Photo Gallery
stuck plug
Twice over the years I have had to mig weld an old wrench, once was allen head plug on to the plug itself. I put a big pipe over the wrench and they came out. I think the heat of the weld helped it come out easy. Oh yeah, disconnect the battery first
J.Vincent is offline   Reply With Quote
Old 12-08-2007, 01:21 AM   #4 (permalink)
Now to the million $ question where do I get the new diff plug if I can get the old one out. My auto store doesn't have one and I cannot find one online.
Old 12-08-2007, 01:24 AM   #5 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
Try the dealership.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 12-13-2007, 03:43 AM   #6 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
Get a syphon pump to remove the diff oil, then refill.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 12-13-2007, 06:23 AM   #7 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I'd try to use an 11mm and knock it in tight. OR, try an inch hex that is a little larger.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Camry O2 Sensor Trouble camryguy623 Camry & Solara Lounge 10 11-25-2005 03:43 AM
1997 Camry tranny problem.. I think! YotaMan21 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-25-2005 10:09 PM
1997 Camry Weapon-R Intake question Dark-LE 3rd & 4th Generation (1992–1996 & 1997–2001) 6 06-11-2005 11:45 PM
Damage to 1997 Camry LE chrono807 General Discussion 8 07-28-2004 04:52 PM
