Buying advice 2001 LE 2.2 Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2007, 06:38 PM   #1 (permalink)
View jac1502's Photo Gallery
I have the option of purchasing a 2001 Camry LE company fleet vehicle cheap $3400 (I guess that’s cheap) The car is in great shape but has 177,000 miles. All normal maintenance has been done but timing belt and the car has never been replaced. No mechanical problem besides a leaky oil pan and a broken door handle that was fixed.
Is this a good deal?
I am very mechanical and have built and worked on several domestics but not much experience with Toyota
What will I be in store for repair wise?
If I do need to replace the engine, what will a new or rebuilt long block run me?
I am looking for a good daily driver even if it has some down time I just want to make sure it wont cost to much for me to repair myself.
Any tips or advice would be greatly appreciated!
jac1502 is offline   Reply With Quote
Old 12-07-2007, 06:45 PM   #2 (permalink)
2000 Cadillac Seville STS
ryannel2003's Avatar
View ryannel2003's Photo Gallery
Hey and Welcome To Toyota Nation!
That seems like a really good deal. I see many high mileage Gen 3 models going for that much. As for the timing belt, get that replaced immediately. You can save a load of money doing it yourself. Toyota charges about $500 to do this; timing belt is supposed to be replaced every 90k miles. as for problems, my car has only had an issue with the sunroof. Most LE Camry's don't come with a sunroof so that might be something you don't have to worry about. I need a whole new sunroof assembly which would set somebody back $1300. I shot down that idea. These cars are very reliable, and many still litter the roads today.
I traded my Camry for a Caddy...
ryannel2003 is offline   Reply With Quote
Old 12-07-2007, 07:22 PM   #3 (permalink)
Thanks that helps!
Old 12-10-2007, 08:05 AM   #4 (permalink)
Anyone else?
Old 12-10-2007, 10:22 AM   #5 (permalink)
There seems to be some confusion regarding the TB replacement period ...I recall that the 5S-FE engine TB should be replaced at 60k mi., whereas the V6 1MZ-FE should be replaced at 90k mi. .... Suggest calling the local Toyota dealer to make sure about this.
Also, it I would personally recommend removing the transmission pan, cleaning, replacing gasket, and probably rinsing out the metal filter/drain ... After doing this and refilling ... the usual procedure is to drive for a while, and then repeat the drain pan and refill an additional 2 or 3 times.... about 2.5 qts per drain cycle for the 5S-FE automatic. This procedure will insure clean transmission fluid, and possibly prolong its working life.
Not sure about the long block .... there are several posters here that claim to have racked up 300k+ miles... There is also a recent topic on whose car has the most miles.
There is an online factory manual that has a lot of useful subjects ... Also a forum 'Search' can be helpful.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 12-10-2007, 11:56 AM   #6 (permalink)
daveart's Avatar
View daveart's Photo Gallery
ive got over 130 km on mine and never had to replace the tb,but hay what do i know,the car is amazing on gas and very reliable,and if you never did the timing belt your self dont do it on this model,if the belt is too tright it will cost you internal bearing on the block and if too loose then it will make noise.get someone who knows what they are doing,
daveart is offline   Reply With Quote
Old 12-10-2007, 11:59 AM   #7 (permalink)
I have read several write ups about the belt and it does not seem all that difficult. Does the belt tensioner not pretty much set itself with the tension spring?
Old 12-10-2007, 01:35 PM   #8 (permalink)
Yes ... upper idler pulley has a tensioner spring .....recommended to replace spring, and at your accumulated miles, probably replace upper idler pulley also ... it has a sealed bearing that will eventually wear out .... probably buy the belt and idler pulley kit.
.... you should read the repair manual 5s-fe mechanical section regarding TB replacement ... there are one or two details, like setting the final torque on the upper idler pulley hold down bolt, which are described in detail, and will eliminate any possible problems.
.... again, the 5s-fe TB replacement has been discussed numerous times previously on this forum .... don't forget to replace the water pump / thermostat.
Old 12-10-2007, 08:21 PM   #9 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
i wouldnt buy that car. IMHO the price is too high for starters with a car with that mileage. secondly, did you know the person that drove that car? i know & work with some sales people who get fleet cars through their work. they literally dont do any maintenance to the cars. the guys i know, even though the company pays for the oil changes, they dont care about the cars and dont want to take the time. they get new cars and rarely change the oil every 30k miles. a couple of them have even locked up the motors on the cars in less then 40k miles due to lack of oil changes. granted this might not be the norm, but it sure is with the sales guys i know and their fleet vehicles .
Old 12-10-2007, 08:31 PM   #10 (permalink)
It was well maintained and did get serviced. They have all the documents the only thing I didn’t find was a receipt for the timing belt so not sure if that was done. It is a fleet vehicle but not one assigned to a specific person it was used for distant business meetings where flying was not considered reasonable. I am fairly comfortable with how it was treated I just want to make sure it could last a few more years. I offered 3250.00 so we will see if they take it. Even at that price because the body and interior are in suck great shape I would think it would be worth a tranny rebuild and a rebuilt engine if it came down to it, don’t you think? Keep in mind this will be one of four cars so I own so its not like I have to have it as a daily driver if something breaks I can fix it at a leisurely pace
Old 12-11-2007, 01:30 PM   #11 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
For the timing belt, check under the hood.. When my mom got the timing belt changed on her gen 3.5, they put a small sticker with the date of replacement and miles on the car at the time.
I don't think you should run into any trouble with the '01 even at that mileage IF it was maintained. The company you're buying it from is great in that they kept records. A friend's aunt drives a company car and the 'driver information center' has displayed 0% oil life remaining for a long time now. I reminded her to get it changed (they get reimbursed) but she doesn't have time.
How's the tranny on the '01 you're looking at? Still shift smoothly? How does the transmission fluid look/smell?
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 12-11-2007, 04:01 PM   #12 (permalink)
The trans fluid was changed twice from the records I have. It shifts smooth and pulls fine and visually I thought it looked good. I looked up some of the oil seal/water pump/timing belt kits on ebay. They seem very reasonable I wonder about the quality. If the seals are not leaking should I replace since I will have it all apart or could that make things worse?
Old 12-11-2007, 06:40 PM   #13 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Stop perpetuating this. Timing belt interval for Gen 4 is 90 thousand miles.
It may have been correct for Gen 3 (I do not know whether or not it is), but for Gen 4, it is not right.
2007 Camry 2.4L 5M
Old 12-11-2007, 07:38 PM   #14 (permalink)
It looks like they changed the TB replacement period in '98 ... prior to that it was 60k.
Originally Posted by toyomoho View Post
The Gates belt guide states the 90K mile recommended change started in 1998.
My Gen 4 Owner's Maintenance Supplement gives a 6 year or 90k mi timing belt replacement period for the vehicle ... a 5S-FE.
After 44k miles and 9 years of driving the car, the water pump was leaking, and the timing belt showed signs of deterioration ... some inside cracks, but still holding together. ...needed to be replaced.
You're right according to the factory recommendation for the Gen 4.
I hope the replacement belt and water pump hold out better than the original parts.... don't think it would have made 90k in one piece.
Old 12-12-2007, 12:29 PM   #15 (permalink)
View steve97's Photo Gallery
Have a friend start the car when it is cold. Stand 6 feet from the trunk and stare at the tailpipe. Do you have a puff of blue smoke come out upon start up? If so, your valve guides will need replaced sooner rather than later.
steve97 is offline   Reply With Quote
Buying Dilemma??? 2003 Camry XLE or 2005 Camry LE bhavinjo Camry & Solara Lounge 8 11-06-2007 09:29 PM
2001 Toyota Camry Le V6 RICHARD LEE 3rd & 4th Generation (1992–1996 & 1997–2001) 1 08-26-2007 02:26 PM
Thinking about buying a Corolla Gen8 in AUS ... any advice blitz_syd Archived Corolla threads 0 10-16-2004 03:10 AM
Buying a 04 corolla LE or S. HELP!!!!!!!! Bigshoguns Archived Corolla threads 6 04-19-2004 11:26 AM
Buying a 2003 corolla LE bearjc99 Archived Corolla threads 1 05-27-2003 03:54 PM
