Junction Produce Scara Wheel 19inch fit the 1994 Camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2007, 11:44 PM   #1 (permalink)
View jdmcamry703's Photo Gallery
http://www.junction-produce.co.jp/en...pan/index.html
I want to know what size width of the 19 inch normal rim can fit the 94 Camry V6. Example, how wide the rim as in 8 inch to 11.5 inch can fit the wheel well so it doent rub the fender. Thanks.
jdmcamry703 is offline   Reply With Quote
Old 12-07-2007, 11:57 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
with 19" wheels ud be hard pressed to fit an 8" width without rolling the fenders. i believe miltdoggy has 19x9s and he had to widen his fenders to fit them.
what offset?
are u lowered?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 12-08-2007, 03:40 AM   #3 (permalink)
no i am not lowered yet. but i have question, what the lowest offset can i put on?
Old 12-08-2007, 11:41 AM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
depends on the widthe wheels u get. if u go 8" then id do around 35mm.
R.I.P.
Car Domain:
Old 12-08-2007, 02:11 PM   #5 (permalink)
Gangsta SC400 & 5.7Tundra
iTrader Score: 35 reviews
View -SCWEET1-'s Photo Gallery
I had a 19x8.5 with a +30 offset, super rolled fenders before I pulled my fenders..... Now with the pulled fenders, my goal is to run a 10 with a 0 or even try for negative offsets.... Oh I love knowing my wheel offsets!!!
-SCWEET1- is offline   Reply With Quote
Old 12-08-2007, 06:36 PM   #6 (permalink)
View charley240sx's Photo Gallery
yeah, cut/roll your wheel wells, and get the desired height first. then you will see how much more room you have to play with. i have a 1997 ES300 1mzfe, 19*9 et+22. you can get 9's to fit.
im actually waiting on a set of 18*10 et -26 for the rears of my 93 es300 which is essentially a 1mzfe 93 camry. i believe the wheel wells should be damn near identical as well.
Charley
charley240sx is offline   Reply With Quote
Old 12-08-2007, 06:38 PM   #7 (permalink)
actually, even with a semi high offset and small width wheel, id imagine you still being able to show some lip because of a slight cheater lip design that these wheels have.
goodluck
Charley
Old 12-09-2007, 12:41 AM   #8 (permalink)
I HAS BOOST!!!
bigbird's Avatar
10" thats gonna look interesting
R.I.P.
Car Domain:
08 Accord EXL-V6 vs Camry SE krispykreme 5th & 6th Generation (2002-2006 & 2007-2011) 17 05-22-2009 10:12 PM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Which stock CD/tape players fit 1999 Camry LE? jbrams 3rd & 4th Generation (1992–1996 & 1997–2001) 5 01-11-2007 08:09 PM
Would a 03 Camry SE airbag fit the Corolla S steering wheel? Camdaddy Archived Corolla threads 2 02-27-2004 01:02 PM
WIll Rims off a Gen 4 Camry Fit a Gen 3 Camry lankanprince 3rd & 4th Generation (1992–1996 & 1997–2001) 2 05-06-2002 04:19 PM
