2000 LE V6 oil filter loose - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2007, 10:17 AM   #1 (permalink)
View bmike74's Photo Gallery
4th Generation 2000 LE V6 oil filter loose
I have a 2000 Camry v6, I had all seals changed about 1 year ago. After a recent oil change at a local jiffy lube, the car started to smell like something was burning. It turned out that my filter was loose. They replaced the filter and added oil. Now, about 3-4 weeks later, same deal, leaking oil slowly, burning smell and, I will likely find out in a minute after it's cool, loose filter. Any ideas?
Thanks
bmike74 is offline   Reply With Quote
Old 12-08-2007, 11:22 AM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
u sure its connin from the filter? the only seals at the filter is the seal that is actually on the filter. if so, then u may want to check the area where the filter seal contacts the engine to make sure there isnt any gouges(for whatever reason) or somthing causing the filter not to seal properly. they may just not be putting the filter on properly, as hard as that can be to screw up.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Toyota avalon 2007 time belt diagram drhusein 3rd Generation (2005-2012) 6 10-30-2007 07:35 PM
oil leak in 2000 V6 rutherford Solara 5 06-17-2007 08:59 AM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
funny oil change docktortal33 2nd Generation (2005+) 7 08-08-2006 03:17 PM
