Replacing Strut Mounts or bearings? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2007, 10:43 AM   #1 (permalink)
View bmmgolf24's Photo Gallery
I'm about 90% sure that the rattling in my front end is being caused by the strut mounts or bearings. Can I replace these or do I need a spring compressor? Does anyone have any experience with this?
bmmgolf24 is offline   Reply With Quote
Old 12-08-2007, 12:23 PM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
You will need a spring compressor to replace them.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 12-08-2007, 12:55 PM   #3 (permalink)
Gameroom cash: $152705
View redgtxdi's Photo Gallery
What year??
How many miles??
Yes, you'll need a spring compressor.
Buy OEM mounts, not any other brand!
redgtxdi is offline   Reply With Quote
Old 12-23-2007, 02:58 AM   #4 (permalink)
View yeskay's Photo Gallery
does the strut mount replacement requires a new alignment. can you do it yourslelf.
yeskay is offline   Reply With Quote
Old 12-23-2007, 07:32 AM   #5 (permalink)
View 1996camry's Photo Gallery
you need alignment after you done with struts....if you don't get alignment done, your tight wear out unveven...i speak from experience because i replaced my front struts and hope save $ for alignment but i ended up uneven wear tires...after got alignment done, they're better now...
1996camry is offline   Reply With Quote
Old 12-23-2007, 04:23 PM   #6 (permalink)
View wahed3001's Photo Gallery
What kind of rattling noise are you getting? I'm having similar problems with my 94 I4 Camry, It's a metal to metal rattling noise from the front left while going slowly on slightly rough roads but no clunks while going over speed bumps. I've been trying to isolate the source of the noise but so far been unsuccessful. Strut mounts I get but what bearings were you talking about?
wahed3001 is offline   Reply With Quote
Old 12-23-2007, 04:34 PM   #7 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
Why would it throw it out of alignment since you don't mess with any of the parts that keep it in alignment
MIC0417 is offline   Reply With Quote
Old 12-23-2007, 06:46 PM   #8 (permalink)
97 Camry '8ball EDITION'
rebel8ball's Avatar
View rebel8ball's Photo Gallery
has that same rattling noise you describe exactly, once it was rockes in my hub caps, anothertime the wheel weight had come loose...
rebel8ball is offline   Reply With Quote
Old 12-23-2007, 11:38 PM   #9 (permalink)
View mitsujh's Photo Gallery
i have changed my struts, strut mounts and buschings and im still gettin an annoying clunking noise from the rear when i hit bumps or pot holes, i cant take it anymore. any ideas?
mitsujh is offline   Reply With Quote
Old 12-24-2007, 01:24 AM   #10 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
did you change the rear sway bar endlinks? They also can make noise but not to sure about the clunking noise more like rattling noise but you never know. How long was it since you changed the strut mount and did you use oem ones.
felonyr301 is offline   Reply With Quote
Old 12-24-2007, 01:59 AM   #11 (permalink)
where are the wheel weights located? on the tires?
Old 12-24-2007, 02:07 AM   #12 (permalink)
rebel8ball's Avatar
when that happened it was on my stock rims with wheel covers, i sorta slid into a curb lightly (right after i got the car, first front wheel drive car i have owned...wet roads were not my friends) and ways i bumped the curb and it knocked it loose (it was clipped on the rim edge) it would slide and rattle and make gawdawful noise i thought i had broke something bad, when i figured out what it was i was much happy, tihghtened back down and it was fine...
Old 12-24-2007, 02:31 PM   #13 (permalink)
i didnt change the sway bar endlinks, i changed the strut mounts last month, didnt use oem ones.
Old 12-24-2007, 07:34 PM   #14 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Front strut mounts and bearings is a good thing to change at the same time because they are both parts that touch each other. Doing the strut mounts solved my clunking problems.
Change sway bar end links only if necessary, meaning take a look at the rubber seals and see if it has been broken or cracked.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 12-24-2007, 09:38 PM   #15 (permalink)
View John5516's Photo Gallery
Are the front strut mounts and bearings the same thing or something different?
John5516 is offline   Reply With Quote
97-01 strut mounts Trdkamuri510 3rd & 4th Generation (1992–1996 & 1997–2001) 8 02-05-2006 08:54 PM
Upper strut Mounts? weaktruk Camry & Solara Lounge 6 06-04-2005 10:38 PM
strut mounts and ground controls yota Camry & Solara Lounge 1 10-14-2004 12:18 AM
Replacing '93 Camry Motor Mounts Expensive? blampke 3rd & 4th Generation (1992–1996 & 1997–2001) 11 11-25-2003 12:57 PM
