Engine temperature variation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2007, 11:30 PM   #1 (permalink)
View lafferty1234's Photo Gallery
I have a 93 Camry I4 with 142K miles. When I drive it I notice that the temperature seems to vary alot. After the car warms up, the gage sits in the middle. Then it rises to about 3/4. Then back to middle. It repeats this process whether I am driving around town, or on the highway. Is this normal?
lafferty1234 is offline   Reply With Quote
Old 12-09-2007, 11:40 PM   #2 (permalink)
Dave's
View Dave's's Photo Gallery
No, might check the fans first. Not sure what's going on however. Maybe someone else will have an idea.
Dave's is offline   Reply With Quote
Old 12-09-2007, 11:58 PM   #3 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $407745
View uibalnme's Photo Gallery
Flushing the cooling system, and changing the thermostat may help. It almost seems like the t-stat isn't opperating properly. In any event, changing the coolant and t-stat would be a cheap fix, and a good idea anyway.
uibalnme is offline   Reply With Quote
Old 12-10-2007, 12:37 AM   #4 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $336721
View ModifierMR's Photo Gallery
make sure your fluids are good, and your resivour is full. If not you may have air in the system, or a bad thermostat.
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 12-10-2007, 02:20 AM   #5 (permalink)
There is a temperature sensor fan switch ... located on lower pass. side of radiator ... might be intermittent failure.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 06-11-2008, 03:52 PM   #6 (permalink)
View dadalior's Photo Gallery
Thumbs up
I have the same problem with my 95 I4. Did you fix this issue? I changed t-stat, problem remains
dadalior is offline   Reply With Quote
Old 06-11-2008, 09:22 PM   #7 (permalink)
Post
Is problem from water pump which causes bad coolant circulation?
Old 06-11-2008, 10:42 PM   #8 (permalink)
Yes I solved the problem. I put in a toyota themostat. It is worth the $ to get one from a Toyota dealership. It now comes up to temp quickly and stays right there.
Old 06-11-2008, 11:12 PM   #9 (permalink)
Post
Thank you very much~~~ My problem is exactly the same as yours. I get the solution! How much did you spend for the TOYOTA thermostat?
Old 06-12-2008, 05:10 AM   #10 (permalink)
Moderator
eyeball96's Avatar
Gameroom cash: $797377
iTrader Score: 59 reviews
I had a simular problem, a few yrs back on a 96 5sfe, but it was the infamous hair line crack at the top of the radiator...might give that a look too, never replaced the thermostat.
eyeball96 is offline   Reply With Quote
Old 06-12-2008, 12:31 PM   #11 (permalink)
Post
Thank you! How did you find out this crack?
Old 06-12-2008, 04:11 PM   #12 (permalink)
Moderator
eyeball96's Avatar
Its usually at the top front of the radiatior...its a hair line crack, look for a greenish stain, with seepage.
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 07:20 PM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 01:05 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 01:49 PM
Jasper remanufactured engine (5sfe) cupcakes 3rd & 4th Generation (1992–1996 & 1997–2001) 10 04-01-2005 05:09 PM
