Valve Guides??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2007, 12:23 PM   #1 (permalink)
View rrkhh's Photo Gallery
Valve Guides???
Hi,i had a used motor installed in my 1998 Camry 4cyl. about 3,4 weeks after i got it back the engine will smoke when i start in the morning.it is a blue smoke.that to me means the valve guides leaking.my question is what is the seals made of ( of what material is the seals )
THANKS
the place that did the install is to replace at no charge
?? what would a shop charge to replace the valve seals???
THANKS Robert...
rrkhh is offline   Reply With Quote
Old 12-10-2007, 04:53 PM   #2 (permalink)
View toyomoho's Photo Gallery
Toyota valve stem seals have a habit of drying up and leaking as you describe if the engine sits without running for weeks/months. Try to find newer seals made of Viton.
The usual procedure is to remove/reinstall the head which can take 6-7 hours. The seals can also be replaced with head still on the block but this is even more time consuming unless the shop is set up for this job.
How to remove the valve cover. 2slo5sfe 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-09-2007 12:26 PM
Valve Guides mrred Hardcore Tech and Competition 5 01-03-2007 09:03 PM
A small mistake... need new valve covers east_stingray 89-95 Toyota Pickup/Hilux 6 12-02-2006 06:19 PM
PCV valve is screwed up... I helped it.. 4EVERCooL 1st Generation (1995-1999) 3 11-14-2005 07:55 PM
