OKay, so there are several differences in the two motors i have. I got a 92 celica 5sfe to swap into my 97 camry (spun a rod bearing)
The mains are the same. THe rod journals are 2.000 compared to the camry's 2.160.
The pistons/bore is smaller as well on the 92 celica motor.
These aren't really areas of concern, even if it was a 2.0L (it clearly said 2.2L 5sfe on the car) all I care about is getting it running.
So heres the problem. The rear motor mount for the celica is on the tranny, and on the camry it goes with the carrier bearing. There are two places on the block with different mounting bosses.
The mounting holes for the carrier bearing/motor mount do not match up with threads on the celica block. As you can see in this picture:
as compared to the this one:
Only the two locating pins and the top right bolt line up.
Also, there is a boss on the front of the motor on the right side pictured here:
That is not present on the celica motor here.
Although, for the life of me, i can't think of what goes there.
Need to solve this carrier bearing, motor mount problem.
(you can see the bearing not matching up in this picture)
