99 v6 starting problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2007, 05:20 PM   #1 (permalink)
View bronxstreets's Photo Gallery
4th Generation 99 v6 starting problems
toyota nation ,i have a problem
my 99 v6 camry ha starting problems. The problem doesnt happen everytime just sometimes.Now the problem is when im ready to start the car,and i crank the key to start the car,the car starts but if the idle needle doesnt past the 1 mark the car loses power and shuts off.
I have kept the doing regular maintance on the car,recently changed all 6 spark plugs and the wire.(i thought having old spark plugs was the main reason for the problem).
Now i need yall help in figuring was is the problem my car is having?
Thanks In Advanced
bronxstreets is offline   Reply With Quote
Old 12-10-2007, 08:40 PM   #2 (permalink)
View NYC_99Camry's Photo Gallery
i have the same problem. i have a 99 le i-4 with about 85K. problem only happens either when it is raining or when it is cold. i took it to my mechanic and he said its the egr and the throttle. just clean out the whole thing and it should be fine. maybe it works for you. but as for my case...it didn't work. my egr is gone bad...so bad that my check engine light came on and when checking the code...it says EGR. i have to replace a new one. but....in the meantime, i'm just sticking to the problem....until next inspection of course. next time if it shuts off again.....just restart it again and step on the gas at the same time....it will bring the idle needle up. hope this works for you.
NYC_99Camry is offline   Reply With Quote
Old 12-10-2007, 09:24 PM   #3 (permalink)
drunken member
CCCP's Avatar
View CCCP's Photo Gallery
Yeah same problem on my 97 V6 doesn't happen often but usually was a problem on hot humid days.
CCCP is offline   Reply With Quote
Old 12-11-2007, 03:41 AM   #4 (permalink)
JvR
JvR's Avatar
View JvR's Photo Gallery
the same here.......also sometimes when i have parked the car for 0.5-1 hour and it is still hot.
JvR is offline   Reply With Quote
Old 12-11-2007, 10:03 AM   #5 (permalink)
MOBB's Avatar
View MOBB's Photo Gallery
Same here when i shut off the car for like 5 mins and re start it it doesn't want to start.. i have to hit gas then it'll start up could it have anything to do with the battery?
MOBB is offline   Reply With Quote
Old 12-11-2007, 11:23 AM   #6 (permalink)
View 2kcamrytnr's Photo Gallery
4th Generation Hmmmmmmmmmm
wow does everyone have this problem???? lol I tried starting my car last night and it took me five times and it sounds like you guys have the exact same problem but it was freezing cold......its not the battery or the spark plugs either, i know that because everything was checked out already
2kcamrytnr is offline   Reply With Quote
Old 12-11-2007, 12:43 PM   #7 (permalink)
.... something wrong with the throttle position sensor?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 12-11-2007, 05:01 PM   #8 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
The EGR valve should be shut at idle and Wide Open Throttle. It should be open during normal running. If it is clogged up and cannot shut it will cause stumbling or kill the engine at idle and cause a lack of power at WOT.
I am not familiar with the V-6 version but the 3SFE and 5SFE are pretty easy to remove and inspect. The built up carbon may be so hard that soaking in cleaning fluid may not help. I had to pick out the carbon with a small screw driver and pick. Also make sure to clean the hole into the throttle body where it attaches and look down the tube that it hooks on to to see if it is plugged up (not likely since you have an open EGR problem).
My favorite suggestion is that while you are in this area you might as well go ahead and clean the IAC valve and the throttle body as well.
Since it is cold, does the V-6 have a cold start valve and timer switch? Those can be checked too.
Kep
Old 12-11-2007, 05:14 PM   #9 (permalink)
JvR
JvR's Avatar
I know that the egr is not the problem with my v6..
The owner before me had blocked the egr.
4 years the same problem.
After i have installed the supercharger i have removed the blocking and have used the carburettor cleaner for the iac valve.
Now sometimes the problem is back.
I think it is the aic.......i had a blocked egr ............the problem still exist
Old 12-11-2007, 09:23 PM   #10 (permalink)
MOBB's Avatar
Well in my Acura TL i had a clogged EGR, the car immediately displayed a CEL... shouldn't be the same on a camry??
Old 12-11-2007, 10:10 PM   #11 (permalink)
yeah...my 99 camry LE does the same. i have a faulty EGR and my CEL has been on ever since then. i was thinking about replacing my EGR. anyone know how much it would cost? i went to my mechanic and he did clean out the whole EGR and throttle and the whole nine yards. but the CEL is still on saying the EGR is faulty. well....i guess i have to change it before my inspection is up.
Old 12-12-2007, 12:16 PM   #12 (permalink)
Kep
Kep's Avatar
NYC_99Camry: Take your EGR out and test it before you go out and buy another one. Just because you have an EGR CEL code doesn't mean that it is the EGR itself that is at fault.
JvR: Do I understand that when the port was blocked that you had the same problem (with or without the CEL?)? That being the case, couldn't it have become clogged or sticky in the meantime? Do the 99s use a modulator? If so, the tubing running between them can get clogged and cause faulty actuation.
Kep
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
95 V6 XLE - Intermittent Starting Problems camree2 3rd & 4th Generation (1992–1996 & 1997–2001) 0 08-15-2006 11:20 AM
Starting problems - Electrical. pdrover Archived Corolla threads 12 02-09-2004 03:55 AM
'99 Tacoma starting problems GuitarCharlie 1st Generation (1995.5–2004) 3 10-20-2003 06:59 PM
Starting problems. Please help. sadik Camry & Solara Lounge 6 09-05-2002 12:02 PM
