Cam gear(Slipping the teeths) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2007, 01:09 AM   #1 (permalink)
View J_Phu's Photo Gallery
3rd Generation Cam gear(Slipping the teeths)
I heard that you can slip the teeth of the cam gear on the 3vzfe so that the intake valve can open sooner, before the exhaust valve closes. Well I been searching around with no luck.
Does anybody know or heard of this?
J_Phu is offline   Reply With Quote
Old 12-12-2007, 01:19 AM   #2 (permalink)
View 94CoupeV6's Photo Gallery
Ummmmmmmmmmmmm no.
94CoupeV6 is offline   Reply With Quote
Old 12-12-2007, 06:57 AM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
on the 3vzfe, does a single cam gear time both cams on the one side? if you had dual timing gears on each side, then MAYBE you can adjust the valves opening and closing.
Old 12-12-2007, 11:36 AM   #4 (permalink)
Actually I'm not sure of your question. But I'll try my best to answer, I believe it's dual timing since both of the cam gears on each sice has little indentations (marks for lining up both gears when putting it back together).
If I have dual timing gears then, how would I adjust it?
Old 12-12-2007, 11:42 AM   #5 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
why would you open the intake valve while the exhaust valve is still open?
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 12-12-2007, 12:03 PM   #6 (permalink)
I want it to open early just before the exhaust valves closes. I'm seeing if I can recreate what VVTI does.
Old 12-12-2007, 12:09 PM   #7 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
It's called overlap, and it's employed to let the engine breathe easier at higher speeds. Problem is that a lot of overlap near idle the engine runs like crap. If you've ever pulled up at a light next to an old muscle car that's all done up, it sounds like garbage while it's idling, but once you get it going it'll scream. Variable valve timing will give you the best of both worlds by having normal timing at low RPM, and then advancing the intake valves at higher speeds for better breathing. Sounds like the op wants to advance the intake cam to get that effect. Who knows why. Maybe he never lets the engine dip below 2500.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 12-12-2007, 12:38 PM   #8 (permalink)
Actually I just want some free performance, sorta speak. So if I do the overlap it'll only be good at higher rpm and low or idling?
Old 12-12-2007, 01:15 PM   #9 (permalink)
Venom_5's Avatar
it makes sense in muscle cars ... but i dont forsee any advantages on a 3VZ-FE ... like you said, its probably going to hurt him more than help him at low rpms
also - youre crazy if you think muscle cars like that sound bad @ idle ... i think they sound like beasts
1MZ Cam marks won't align dgspencer Camry & Solara Lounge 5 03-15-2006 08:32 PM
Part 2: Advancing cam timing allblackalltrac Hardcore Tech and Competition 0 04-16-2004 05:27 PM
Every one say hello to Euro Cam II (warning 19 pics) EuroCamz Camry & Solara Lounge 39 04-01-2004 05:03 PM
