94 Camry brake lights Suddenly stopped working!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2007, 03:27 PM   #1 (permalink)
View mikeywsp's Photo Gallery
Post 94 Camry brake lights Suddenly stopped working!!
My Brake lights stopped working suddenly!! 94 toyota camry XLE!! All fuses and bulbs still good!! Can anyone please help!! Thank you!!
mikeywsp is offline   Reply With Quote
Old 12-13-2007, 03:55 PM   #2 (permalink)
Inspect the trunk lid hinge ... look for broken wires or bare insulation.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 12-13-2007, 04:19 PM   #3 (permalink)
Gameroom cash: $303055
I think dc_98_cam means the loom of wires, located by the driver's side trunk hinge. Open up that loom and look for frayed or broken wires. Repair as necessary.
Mike
Old 12-13-2007, 05:04 PM   #4 (permalink)
Those wires look intact, nothing loose or out of place. Also, I hadn't opened my trunk anytime recently, until today. But I still tried wiggling them, but they all look good. The guy at the auto part store said it might be my brake sensor under the pedal???
Thank you though for the prompt replies!!!!
Old 12-13-2007, 06:26 PM   #5 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
Follow your brake pedal up. There should be a switch or sensor which activates the brake lights when the pedal is depressed. Usually pretty simple once you figure out how to contort your body to reach it.
Dave's is offline   Reply With Quote
Old 12-13-2007, 10:09 PM   #6 (permalink)
View 1996camry's Photo Gallery
can you describe a little more? what do you mean brake is not working? you mean when you push all the way down ..there is not resistance at all? if a sensor goes bad, u get engine check light..i don't think a sensor...
do you get any resistance all when u push it down....
your brake booster could be go bad...
1996camry is offline   Reply With Quote
Brake lights not working :-( Heathman 7th Generation (1993-1997) 1 11-26-2007 12:02 AM
Toyota Camry Remains America's Best-Selling Passenger Car humanoid Toyota News 0 10-06-2007 03:04 PM
92 Camry brake lights problem HAZMAT13 3rd & 4th Generation (1992–1996 & 1997–2001) 6 01-17-2005 03:23 PM
89 Camry problem: lights flicker when I brake ubongen 1st & 2nd Generation (1983–1986 & 1987-1991) 2 01-25-2004 04:35 PM
Changing brake pads on 94 Camry JohnCWms27 3rd & 4th Generation (1992–1996 & 1997–2001) 13 12-18-2003 10:20 PM
