trouble removing speed sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2007, 08:08 AM   #1 (permalink)
View blakesphere's Photo Gallery
3rd Generation trouble removing speed sensor
I just don't get it. How do you get the ABS speed sensor out of the front wheel steering knuckle. I've removed the bolt holding the sensor. But the sensor itself won't budge. I broke one in half already in attempting removal.
Friction fit?
Does it screw in?
What's holding it fixed in place?! Rust?
cheers,
Blake
95 Camry LE
blakesphere is offline   Reply With Quote
Old 12-15-2007, 09:46 AM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I haven't messed with the speed sensors (not on my Camry). This may be a clue though. The on-line manual says to torque it down to 48 inch pounds when installing it. Sort of suggests that it is threaded. The drawings for the rear sensor look like it might have threads.
Pull up the Brake section of the manual and do a search for "Front Speed Sensor Removal" and scroll down a few pages.
Kep
Old 12-15-2007, 05:09 PM   #3 (permalink)
View toyomoho's Photo Gallery
The sensor may be frozen in place try using some penetrating oil.
Old 01-05-2008, 05:49 PM   #4 (permalink)
mag
View mag's Photo Gallery
Did you get your speed sensor out? I have the same problem, can not get it out, I removed the bolt but no go...
mag is offline   Reply With Quote
"Check engine light" error codes po446, po442, po440???? serabell xA Forum 10 04-12-2009 10:31 PM
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
2005 Sport 4Runner with 33 inch tires wants to recalibrate speed sensor 05SPORT1 4Runner Lounge 0 10-19-2006 11:59 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
