Quick Alignment Q. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-15-2007, 03:17 PM   #1 (permalink)
The Greatest
View CamNub's Photo Gallery
4th Generation Quick Alignment Q.
Do these cars need a 4 wheel or 2 wheel alignment?
CamNub is offline   Reply With Quote
Old 12-15-2007, 03:42 PM   #2 (permalink)
The Greatest
Alright, so it's different from my Volvo then right?
These cars require 4-wheel alignments. The rear toe is adjusted first, then the front is adjusted and tracked to the rear. They both work together, it's not 2 seperate alignments.
Old 12-15-2007, 03:54 PM   #3 (permalink)
The Greek....
GrkBallaG's Avatar
iTrader Score: 13 reviews
View GrkBallaG's Photo Gallery
Originally Posted by freestylez View Post
just the two front wheels
No, obviously you dont know anything.
You need a 4 wheel alignment, the back is adjustable on a camry.
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 12-15-2007, 03:56 PM   #4 (permalink)
The Greatest
The car is pulling left very hard.
Old 12-15-2007, 04:08 PM   #5 (permalink)
The Greek....
GrkBallaG's Avatar
Yes, the promblem might be in the front but you have to align the back first before you can align the front.
It depends on the type of car, like trucks for instance with solid axles, the back is not adjustable, so its only a 2 wheel alignment for them, and so on.
The SLAMry.....
Old 12-16-2007, 12:23 AM   #6 (permalink)
View Novice_cardude's Photo Gallery
First off, yes you need a 4-wheel alignment. The only factory adjustments for the Camry are front and rear toe. You can get a little camber movement from the struts as well, but it's usually only about 3 tenths of a degree.
If it's pulling hard left, check your tire pressure, tread from one side to the other, and make sure it's not just an off-center steering wheel situation. Because as far as an actual front angle alignment pull on a Camry, there's not much you can do except replace bent parts
'96 4cyl 5spd Camry
147k miles and running out of things to fix...
Novice_cardude is offline   Reply With Quote
Old 12-16-2007, 05:11 PM   #7 (permalink)
View Bear95's Photo Gallery
[quote=Novice_cardude;2096818]First off, yes you need a 4-wheel alignment. The only factory adjustments for the Camry are front and rear toe. You can get a little camber movement from the struts as well, but it's usually only about 3 tenths of a degree.
If it's pulling hard left, check your tire pressure, tread from one side to the other, and make sure it's not just an off-center steering wheel situation. Because as far as an actual front angle alignment pull on a Camry, there's not much you can do except replace bent parts[/quot
You could be getting radial pull from your tires. Swap the front tires and if it makes any difference. And yes, you need 4 wheel alignment on these cars.
Bear
Bear95 is offline   Reply With Quote
Alignment specs sluggo 5th & 6th Generation (2002-2006 & 2007-2011) 9 07-16-2007 09:10 AM
Toyota's front-end alignment kemo sabe 1st Generation (2000–2006) 4 06-04-2007 06:44 PM
Tire replacement and wear Texas_robert 1st Generation (1995.5–2004) 33 04-25-2007 07:24 AM
Steering rack boots torn into two pieces after a firestone alignment, need input ruoknow Camry & Solara Lounge 10 11-17-2005 03:39 PM
Strut bar and alignment!!! need help Vampress Camry & Solara Lounge 17 06-28-2003 11:31 PM
