Certain battery defects cause it to hold a sort of surface charge, where it reads 12.6 or so volts, but in fact is not storing a sufficient amount of electrical energy to start the car... Might be worth the effort to remove the battery, take it to a parts store for testing.
If you choose to examine the main fuse, it has been described as a box with clasps, located on the driver side fender wall, inside the engine compartment, underneath the air intake or battery tray area .... Not sure if it is actually a fuse, or is a fusible link.
Seems like it was 120A rating.... If you want to look at the Gen 3 wiring diagram pdf, it is in the downloadable Gen 3 online repair manual at the top section of the forum page.
How old is the battery?
Another battery test, if you think it is still good, is to find a length of wire, maybe #12 gage or larger, and jump from the +pos terminal to the starter motor terminal ... You should observe the starter motor making some kind of effort to turn over.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
